I can't take a picture of mine right now but I did once, back in the depths of time, before eBay, buy one of each of the Sinclair calculators.
I think there are approx 19 "different" ones.
If there's no silicon heaven, then where do all the calculators go?
Re: If there's no silicon heaven, then where do all the calculators go?
I have the programmable and the scientific Sinclair Cambridge models from the top photo somewhere about, I still use the programable one when I need a calculator.
I have to say, I find the Sinclair calculators to be very stylish, I do like the industrial design a lot.alexh wrote: 16 Jan 2025 14:59 I can't take a picture of mine right now but I did once, back in the depths of time, before eBay, buy one of each of the Sinclair calculators.
Nice little collection, do you still have them? Your posts suggests 'yes but they are not so easy to get to' :)
The oldies are the best :)PhilC wrote: 16 Jan 2025 15:09 I have the programmable and the scientific Sinclair Cambridge models from the top photo somewhere about, I still use the programable one when I need a calculator.
My first calculator, which I fried by attaching the battery the wrong way around in the late 70s, was a Texet 880 "Executive".
Looking on eBay the prices of these are really silly, for what was even in the mid-70s a "budget" calculator.
Note: The battery is a PP3, 9V one but the battery bay requires you to press fit the battery in without and polarity restriction. Stupid.
DoG
I found my fathers old calculator. It's a SHARP EL-805. Google it and found that is the first calculator with LCD. Most of display still work. I don't know if one could get the numbers working again somehow.
Very neat. I think the trouble with older LCDs is they are difficult to repair. My brother gave me a Sharp handheld computer and the display only worked in a couple of spots, just enough to know it worked.DoG wrote: 16 Jan 2025 16:09 I found my fathers old calculator. It's a SHARP EL-805. Google it and found that is the first calculator with LCD. Most of display still work. I don't know if one could get the numbers working again somehow.
I was able to get a replacement LCD from the US, but it wasn't cheap and was difficult to fit. The point being that for custom stuff it's not always so easy.
I did repair the LCD on one of my Wonderswan consoles, but that was down to the polarising film going bad, and it was possible to replace just that.
So I pulled it apart and it's a fairly simple single IC model with a few discrete components:
The button matrix seems fairly simple with 4 connectors across and 5 vertically, so checking the necessary pins showed the decimal point button to be working.
What weren't working were the two electrolytic capacitors which were reading low and had turned into a resistor respectively. I'll fit some new ones later.
Users browsing this forum: apple [bot], ClaudeBot, nicknm and 9 guests
