Okay, I finally caved in and tore the entire thing down to "bare metal", as the saying goes.
I removed all the drives, cables, connectors, etc from the drive cage and started over,
hopefully with better cable management and layout.
It turns out, I was on the wrong trail all along. The problem had nothing to do with the
1.44 HD floppy PCB. Honestly, I always thought it was strange that pushing down on it
(it's socketed, after all) made it stop working. What threw me off was that half the time
I was getting the damage drive A message and the other half it would read 1.44 floppies
but not 720k ones. Going from that I assumed it had to be something to do with the
1.44 mod.
It wasn't pressure going *down* - it was pressure going *up*, into the floppy drive itself.
I realized this after I took everything apart and began reassembling it. I was finally able
to see exactly what was what and it became evident that the 1.44 HD PCB wasn't being
pressed against at all. Same for any associated cable, connectors or wires. As soon as
I arrived at this point, with a little more investigation, it became obvious that the
internal Ultrasatan, and it's height, was the heart of the problem. That's why whenever
I took the floppy drive screws loose, or moved the drive out of the cage, but still being
connected, everything would still work.
I dropped all the way back to the first generation (well, first one I ever had) Ultrasatan
and used it. It seems to work fine. Here are some pictures showing some models of the
Internal Ultrasatan and how it's changed.
First is the 3rd generation (I'm guessing), marked as "Ultrasatan 2k23". It's the one I've
been banging my head against the wall, trying to get it to work. The red arrows point
to the problem - it's just too tall now for what I need:
- 3rd_gen-B.JPG (301.34 KiB) Viewed 1715 times
Next is the 2nd generation (marked as v1.2) and it's what I have in my Mega STe.
Notice how much flatter it is then the one above? I didn't feel like pulling the one
out of my Mega STe to try it and besides, I don't have a 3D printed face plate to
match for the STacy. I'm thinking it might have worked though (maybe):
- 2nd_gen.JPG (53.51 KiB) Viewed 1715 times
and finally, here is what I got to work. It's the original model that I bought years
ago. It's actually not an internal model, I just made it into one. Notice how much
smaller it is than the models above. It doesn't mount the 2 SD-cards side by side,
but rather stacks them vertically:
- 1st_gen.png (338.99 KiB) Viewed 1715 times
Here is an open ended view of it mounted in the STacy's drive bay. You can see how
much smaller it is. I custom made a face plate for it, using the original cover.
- My Setup.jpg (163.54 KiB) Viewed 1715 times
So where do I go from here? I'm thinking I might grab one of the 2nd generation
models (RetroLemon still sells them at the moment), get a 3D printed face plate
to match, and try it to see if it will work. For now though, I've got a working
setup, which means a lot to me.
