Ijor's analysis work has paid off. It runs Closure :D :D
http://www.atari-forum.com/viewtopic.ph ... 18#p355918
Cycle exact FPGA recreation
Re: Cycle exact FPGA recreation
Whats that for exactly a new mist core or something ?
troed
Well MiSTer*, but it means there's finally cycle exact VHDL implementations.
*) https://github.com/MiSTer-devel/Main_MiSTer/wiki
sandord
That sounds wonderful!
I'm very curious what this could mean to the future of the STF Remake Project.
I'm not really sure, because the suska ones were direct replacements for chips, MiST doesn't have a lot of signals as its all internal, so you can't really use these cores (AFAIK) with the stuff I am doing.sandord wrote: 22 Oct 2018 17:19 I'm very curious what this could mean to the future of the STF Remake Project.
In case of the STF, its uses a real CPU, and other chips are locked into 8MHz clock, so even if the cores are not 100% timing wise, it probably won't matter.
ijor
The cores weren't specifically designed for MiST or MiSTer. It is possible to use them as a replacement for real chips with some minor modifications. This wasn't tested though.exxos wrote: 22 Oct 2018 17:53I'm not really sure, because the suska ones were direct replacements for chips, MiST doesn't have a lot of signals as its all internal, so you can't really use these cores (AFAIK) with the stuff I am doing.sandord wrote: 22 Oct 2018 17:19 I'm very curious what this could mean to the future of the STF Remake Project.
To be honest, and once you design for FPGA cores, I don't understand why you would want separate FPGA chips. It is much better in almost every sense, and even cheaper, to use a single unified FPGA. But oh, well, this is none of my business.
http://pasti.fxatari.com
Because as you know there is already MisT, Firebeee, Suska, we are not wanting to make another "clone". Currently there is no 100% backwards compatibility, that was main aim of project, plus fixes and easier upgrades. Though FPGA is looking unlikely as I don't have time to go into all that anyway.ijor wrote: 01 Dec 2018 08:44 To be honest, and once you design for FPGA cores, I don't understand why you would want separate FPGA chips. It is much better in almost every sense, and even cheaper, to use a single unified FPGA. But oh, well, this is none of my business.
MasterOfGizmo
I actually think there's something in between the MiST and your board. That's a board that fits into the original ST case, has all the connectors a real ST had and is otherwise made of one or more FPGAs. The functionality would be the same as your device but you wouldn't have to rely on slaughtered STs. Maybe that's something for a time when used ST's become rare.
we are already looking into this, we had some limited success with the blitter using the suska core. Ultimately we want to replace the chips which are no longer obtainable in a single FPGA. Really we would want them to be as compatible as possible to the originals. But that is pretty much the long-term goal. Of course we don't want to go full FPGA, as we do not want to start recreating the MiST / suska as obviously that already exists :)MasterOfGizmo wrote: 08 Oct 2019 12:50 I actually think there's something in between the MiST and your board. That's a board that fits into the original ST case, has all the connectors a real ST had and is otherwise made of one or more FPGAs. The functionality would be the same as your device but you wouldn't have to rely on slaughtered STs. Maybe that's something for a time when used ST's become rare.
