TF1260 IDE speed
patracy
TF1260 IDE speed
Just curious, what speed should I see from the TF1260's IDE? I have only seen up to about 1.6mb/s. This is also the same top speed I've seen from the onboard 1200 IDE with the 4xIDE and gale adapter. I thought perhaps it was the SD card, so I tried a different one, along with a different adapter. Then tried simply a CF card and adapter. Still seeing the same top speed for IDE no matter what port it's connected to. Not saying this is any way the fault of the TF1260 as it's had the same speed before. But I thought it'd at least be different on the onboard IDE.
3.2.2, with burned kickstart roms that have EHIDE loaded on them.
iluvator
Re: TF1260 IDE speed
I remember was having the same issue when I first upgraded to a TF1260. Problem solved immediately after a fresh installation of mmulib and I was getting 5-6 Mb/s after.
supaduper
Besides installing MUlibsx06080 Also you must use a Mapper like MUfastrom to speed things up, link below
http://aminet.net/package/util/boot/MuFastRom
patracy
Thanks, I'll take a look at both. I think MMULibs is installed, but perhaps it's not correctly setup.
- Admin sponsor
If you are getting 1.6Mb/s it is because the ehide code is running out of ROM (i.e. very slow). You might have MMULibs installed ok but you need to run MuFastROM in order for the driver to be moved into fastram and for it to execute at top speed. By default MMULibs doesnt run MuFastROM after its installed and if you were running ehide.device loaded with loadmodule before and it was working fast then again its because the ehide.device was in faster access memory before and now its been put to slow rom.patracy wrote: 29 Oct 2023 13:17 Thanks, I'll take a look at both. I think MMULibs is installed, but perhaps it's not correctly setup.
patracy
Thank you everyone for the advice. I loaded MuFastRom and presto 6mb/s!
supaduper
This is why Exoss is one of the best retro sites there is as we are all here to help each other without the sniping you have on some sites, glad you are sorted fella ;)patracy wrote: 31 Oct 2023 00:23 Thank you everyone for the advice. I loaded MuFastRom and presto 6mb/s!
f1lupo
I'm happy AlenPPC told me about MuFastROM when he built me my TF1260 as it's a good 3X faster than the onboard IDE on my system
addicted to Amiga hardware for far too long :twisted:
Tygerboi
Does this speed issue still apply if the Amiga (1200/4000) is running Kickstart 3.2.2 ROMs / Workbench 3.2.2 as ehide code is integrated? Would it still be necessary to run MuFastROM in this environment to get the fastest speeds?terriblefire wrote: 30 Oct 2023 08:49If you are getting 1.6Mb/s it is because the ehide code is running out of ROM (i.e. very slow). You might have MMULibs installed ok but you need to run MuFastROM in order for the driver to be moved into fastram and for it to execute at top speed. By default MMULibs doesnt run MuFastROM after its installed and if you were running ehide.device loaded with loadmodule before and it was working fast then again its because the ehide.device was in faster access memory before and now its been put to slow rom.patracy wrote: 29 Oct 2023 13:17 Thanks, I'll take a look at both. I think MMULibs is installed, but perhaps it's not correctly setup.
- Admin sponsor
ehide isn't in 3.2.2 by default. unless someone added it for you.Tygerboi wrote: 06 Sep 2024 02:37Does this speed issue still apply if the Amiga (1200/4000) is running Kickstart 3.2.2 ROMs / Workbench 3.2.2 as ehide code is integrated? Would it still be necessary to run MuFastROM in this environment to get the fastest speeds?terriblefire wrote: 30 Oct 2023 08:49
You need ROM running out of RAM (cpu fastram, mufastrom or some memory mapped rom) to get max speed.
Users browsing this forum: alenppc, ClaudeBot and 26 guests
