This is great advice as Noctua fans are better quality & quieter too :)HigashiJun wrote: 26 Mar 2024 11:37 Concerning the link I sent in my previous post, you can also remove the 5V fan from the heat sink and replace it with a Noctua NF-A4x10 FLX.
You will then have a 12V fan with a 3 pin connector.
Longer screws will be needed.
TF1260 CPU fan
f1lupo
Re: TF1260 CPU fan
addicted to Amiga hardware for far too long :twisted:
Re: TF1260 CPU fan
8-)f1lupo wrote: 12 May 2024 15:54 This is great advice as Noctua fans are better quality & quieter too :)
f1lupo
Re: TF1260 CPU fan
JLCPCB said they can't change the dimension to 58.2*53 since the actual file is 58.22*47.26. Where can I get the files with the proper dimensions?go0se wrote: 22 Mar 2024 21:40
DSC_0262.resized.JPGDSC_0258.resized.JPGDSC_0255.resized.JPGDSC_0254.resized.JPGDSC_0252.resized.JPGDSC_0249.resized.JPGDSC_0248.resized.JPGScreenshot from 2024-03-22 21-01-40.pngScreenshot from 2024-03-22 21-03-11.png
Ordering information is included in the last two images. Be sure to note the base material and the PCB thickness specified for each. JLCPCB now only offer black or white finish Aluminium PCBs with black charged at an excessive premium for small batches. (Order the white). The sandwich layer PCB should be 1mm thick.
f1lupo
go0se
Re: TF1260 CPU fan
The order sheet for the bottom plate should then look as follows :f1lupo wrote: 02 Sep 2024 16:43 JLCPCB said they can't change the dimension to 58.2*53 since the actual file is 58.22*47.26. Where can I get the files with the proper dimensions?
f1lupo
Re: TF1260 CPU fan
but that's the same dimensions? As per your comments above the dimensions need to be 58.2mm*53mm. JLCPCB said they can't change the dimension to 58.2*53 since the actual file is 58.22*47.26. Where can I get the files with the proper dimensions of 58.2mm*53mm?go0se wrote: 11 Sep 2024 09:09The order sheet for the bottom plate should then look as follows :f1lupo wrote: 02 Sep 2024 16:43 JLCPCB said they can't change the dimension to 58.2*53 since the actual file is 58.22*47.26. Where can I get the files with the proper dimensions?
go0se
Re: TF1260 CPU fan
58.22mm * 47.26mm are the correct dimensions for the bottom plate and the previously attached files are correct. There is no need to change any dimension other than the PCB Thickness, which should be set to 1mm for the bottom plate and left at 1.6mm for the top plate.
Bottom Plate :
Gerber file: Universal_Heatsink_Lower_TF360_BIG_BOX_VERSION.zip
Base Material: FR-4
Dimension: 58.22 mm* 47.26 mm
PCB Thickness: 1
PCB Color: Black
Mark on PCB: Order Number(Specify Position)
Top Plate :
Gerber file: Universal_Heatsink_Aluminium_Noctua.zip
Base Material: Aluminum
Dimension: 65.47 mm* 47.2 mm
PCB Thickness: 1.6
PCB Color: White
Bottom Plate :
Base Material: FR-4
PCB Thickness: 1
PCB Color: Black
Top Plate :
PCB Thickness: 1.6
PCB Color: White
f1lupo
Re: TF1260 CPU fan
@ goOse
ok thanks for the clarification
