i have my adapter that have arrived and looking at building them.
first-
has anyone else built them and if so which way round do you build them,
from what i can see you solder in the set of inner long pins for each side then the socket then outer pins, would this be right?.
second,
once built do you push them all the way down to the sts board solder in and cut legs down or leave then high on the board?.
funcky plcc adapters
Re: funcky plcc adapters
Have you looked at the build instructions here: https://exxosforum.co.uk/atari/last/blitter/index.htm
thecaver99
no as that didnt show when searching, thank you for the link as that will heal greatlyrubber_jonnie wrote: Fri Aug 16, 2024 9:33 pm Have you looked at the build instructions here: [https://exxosforum.co.uk/atari/last/blitter/index.htm
Just for future reference there is a note on the site:thecaver99 wrote: Sat Aug 17, 2024 10:25 amno as that didnt show when searching, thank you for the link as that will heal greatlyrubber_jonnie wrote: Fri Aug 16, 2024 9:33 pm Have you looked at the build instructions here: [https://exxosforum.co.uk/atari/last/blitter/index.htm
So the 'i' button will always take you to the help pages for an item if you're ordering any more parts in the future
There is a typo (leading bracket) on the link https://exxosforum.co.uk/atari/last/blitter/index.htmrubber_jonnie wrote: Fri Aug 16, 2024 9:33 pm Have you looked at the build instructions here: [https://exxosforum.co.uk/atari/last/blitter/index.htm
Fixed, stupid paste on my mobile...sporniket wrote: Sat Aug 17, 2024 10:37 amThere is a typo (leading bracket) on the link https://exxosforum.co.uk/atari/last/blitter/index.htmrubber_jonnie wrote: Fri Aug 16, 2024 9:33 pm Have you looked at the build instructions here: [https://exxosforum.co.uk/atari/last/blitter/index.htm
