funcky plcc adapters
thecaver99
Post by thecaver99 »
i have my adapter that have arrived and looking at building them.
first-
has anyone else built them and if so which way round do you build them,
from what i can see you solder in the set of inner long pins for each side then the socket then outer pins, would this be right?.
second,
once built do you push them all the way down to the sts board solder in and cut legs down or leave then high on the board?.
Re: funcky plcc adapters
Have you looked at the build instructions here: https://exxosforum.co.uk/atari/last/blitter/index.htm
thecaver99
rubber_jonnie wrote: Fri Aug 16, 2024 9:33 pm Have you looked at the build instructions here: [https://exxosforum.co.uk/atari/last/blitter/index.htm
no as that didnt show when searching, thank you for the link as that will heal greatly
thecaver99 wrote: Sat Aug 17, 2024 10:25 am
Just for future reference there is a note on the site:
Screenshot 2024-08-17 at 10.30.22.png (194.84 KiB) Viewed 626 times
So the 'i' button will always take you to the help pages for an item if you're ordering any more parts in the future :)
sporniket wrote: Sat Aug 17, 2024 10:37 am
There is a typo (leading bracket) on the link https://exxosforum.co.uk/atari/last/blitter/index.htm
Fixed, stupid paste on my mobile...
