Hmmm, that is not the original I used.
It was first discussed here :
https://www.forum64.de/index.php?thread ... ffperoxyd/
And it came over to a1k.org about the same day.
I think it was about a year later it came over to EAB still the liquid formula
https://eab.abime.net/showthread.php?t=37808
The idea for using hairdresser creme instead of liquid H2O2 came about a week or two after the original post in 2007 but by then lots of people were trying it.
That original formula with gum in may have been around the same time, but that webpage dates to 2009
Not that it matters at all. Just interesting
RJ's Retrobrite investigations
Re: RJ's Retrobrite investigations
As often with things like this, sometimes the same things are discovered by different people at different times. I'd not seen the original post you mention. Interesting history though.alexh wrote: 12 Aug 2024 21:49 Hmmm, that is not the original I used.
I searched a lot when I was looking to see if it could be done and never came across that site, if I had I may have had more success and not bothered with the method I chose, which put me off for years.
OK, so here is the result. of a couple of days in the sun in a H2O2 and H2O mix.
Before:
After:
Before:
After:
Before:
After:
I think the results are OK overall and whilst not perfect, a definite step above the original brown.
Before:
After:
Before:
After:
Before:
After:
mgi
I think it is looking much better and also not too bright so well done!
Cheers
Michal
Cheers
Michal
Thanks :)mgi wrote: 13 Aug 2024 15:47 I think it is looking much better and also not too bright so well done!
Cheers
Michal
Slightly blotchy in places but not too bad.
mrbombermillzy
The proof of a great improvement rests in the fact that the kbd/function keys are not a whole league of shades different! ;)
I think thats a good enough job, considering the variability of retrobriting.
Indeed it's not 100%, and I haven't fully cleaned it yet either so there are some water marks I need to get off, but I'm overall quite pleased, it's a massive improvement over what it was. I have a Mega ST that is quite bad, so I may have a go at that.
Yes, they're pretty close now, and it's also difficult to see it in a good light with the pictures, it looks better in person.mrbombermillzy wrote: 13 Aug 2024 18:42 The proof of a great improvement rests in the fact that the kbd/function keys are not a whole league of shades different! ;)
When I did mine the worst areas of non-uniformity were places where human hands had touched lots.
Around the reset button, floppy drive facia and eject, middle of the space bar (and just in front of the space bar on the case), arrow keys (and just below them on the case).
I thought that perhaps sweat/oils (hand cheese) had seeped into the plastic and changed the UV nature of the plastic or worn down the top layer?
Users browsing this forum: apple [bot], ClaudeBot and 3 guests
