IDE adapter master/slave
IDE, ACSI etc kits and products.
Glorfindeal
Post by Glorfindeal »
I’m looking for an ide to cf adapter that can be set to slave. I’m looking to set up 2 cf cards in my falcon.
Thanks,
Re: IDE adapter master/slave
Most CF adapters have a jumper to set master/slave
https://www.exxosforum.co.uk/atari/store2/#0036
Glorfindeal
exxos wrote: 05 Aug 2024 22:16 Most CF adapters have a jumper to set master/slave
I have your adapter. What jumper setting puts it into slave?
Thanks
Glorfindeal wrote: 06 Aug 2024 09:50 I have your adapter. What jumper setting puts it into slave?
I assume removing the jumper would be slave. Its simple enough to try both settings with HDdriver though.
Thanks
That is entirely dependent on the CF adapter. Some have jumpers, some dual CF adapters have jumpers, some define master and slave by the CF card position on the adapter.
There are so many different variants of CF adapter it's a bit of an impossible task if you don't post a picture of your specific adapter.
frank.lukas
Post by frank.lukas »
Return to “HARD DRIVES”
