I’m looking for an ide to cf adapter that can be set to slave. I’m looking to set up 2 cf cards in my falcon.
Thanks,
IDE adapter master/slave
Glorfindeal
Re: IDE adapter master/slave
I have your adapter. What jumper setting puts it into slave?exxos wrote: Mon Aug 05, 2024 10:16 pm Most CF adapters have a jumper to set master/slave
https://www.exxosforum.co.uk/atari/store2/#0036
Thanks
I assume removing the jumper would be slave. Its simple enough to try both settings with HDdriver though.Glorfindeal wrote: Tue Aug 06, 2024 9:50 am I have your adapter. What jumper setting puts it into slave?
That is entirely dependent on the CF adapter. Some have jumpers, some dual CF adapters have jumpers, some define master and slave by the CF card position on the adapter.Glorfindeal wrote: Tue Aug 06, 2024 9:50 amI have your adapter. What jumper setting puts it into slave?exxos wrote: Mon Aug 05, 2024 10:16 pm Most CF adapters have a jumper to set master/slave
Thanks
There are so many different variants of CF adapter it's a bit of an impossible task if you don't post a picture of your specific adapter.
- frank.lukas
