FIRST PRINT
At this point I had not yet connected it to my Wi-Fi. That was a total nightmare, but I don't think the IP & MAC binding works properly in my TP_LINK VR400 router
so I don't believe there was any problems with connectivity actually relating to the printer itself.
So initially I used the 3D-benchy which supplied on the USB stick as gcode. You have to set the bed position manually with the supplied "paper" but that was super simple. Normally I can spend several days fighting with that aspect alone on other printers!! Then the auto bed levelling seems to work fine as well.
My first impression was that this printer is extremely fast!! I would there even to say it is too fast or scary fast even
If anyone is interested in some footage of the first print and I can do a video..
These are the images of the first print...
Sometimes it looks like there is bad "banding" for artefacts but it seems to be a trick of the light more than anything somehow. I don't think the shiny PLA helps and being black isn't helping. I have seen other reviews mentioning this "problem" as well.
- IMG_2559.JPG (420.34 KiB) Viewed 1608 times
- IMG_2560.JPG (411.58 KiB) Viewed 1608 times
- IMG_2561.JPG (404.71 KiB) Viewed 1608 times
- IMG_2562.JPG (338.17 KiB) Viewed 1608 times
- IMG_2563.JPG (300.79 KiB) Viewed 1608 times
- IMG_2564.JPG (340.78 KiB) Viewed 1608 times
- IMG_2565.JPG (425.52 KiB) Viewed 1608 times
- IMG_2566.JPG (327.07 KiB) Viewed 1608 times
Generally I have used a 0.2mm nozzle to gain better details. Adjusting the layer height alone does not really help in some cases.
I have also printed a few of my "68K dummy CPUs". These printed in under three minutes which is great and they seem really accurate as well! Before I would have to print out and fight with the printer for about 50 prints before I got the thing to behave!
I eventually got it connected up to Simplify3D. The default profile seem to work fine. I also emailed QUDI as at the time I could not find profile , they responded quickly and gave me the link to download the profile. However the profile they sent seems broken.
First off the printer head seem to bang against the edge of the case. Then it started printing in midair without moving the base. There there was no filament flowing (more on this shortly) and then the printer bed seem to want to go through the bottom of the printer banging about like the printer was trying to destroy itself! So I just turned it off at the mains!
There printer profile as different settings to the default one in Simplify3D. So I created my own profile variant to try out next. Though there is no filament extruding at all.
Though I did try printing my ST2VGA case before.. Started looking a little bit ropey and then the printer said print was complete even though it had only done about 50%:WTF: so I don't know what happened there...
- IMG_2570.JPG (435.46 KiB) Viewed 1608 times
Though since printing that object has been no filament extruding. The next I will try priming the head again as I assume it has got stuck or just become unloaded while I was testing the QIDI profile...
