BlueSCSI 2 query
nolina
Re: BlueSCSI 2 query
Post by nolina »
Hi,
this one.
https://studio-services.de/produkt/scsi ... niq-asr-x/
On the picture there is a gender change but the one i got a month ago came without because it has a female D-Sub 25-pin connector already.
Regards.
smoore100
Post by smoore100 »
BluesSCSI 2 arrived total, but as is typical of my luck I don't have the right lead!
I was hoping to use the one from my Jazz drive, but nope - fits in the falcon but not the BlueSCSI - more shopping!
Cheers,
Simon
smoore100
Post by smoore100 »
And I can't find one - 50 pin to 68 pin, is that correct?
smoore100
Post by smoore100 »
Or are both ends 50 pin and I need to buy an adapter to connect to the BlueSCSI?
viewtopic.php?f=29&t=7050
As to not retread recently covered ground :)
smoore100
Post by smoore100 »
Thanks Steve
I had a look through that thread and I'm being far too stupid to understand what to get - either that or my eyes are failing me.
The connector in the BlueSCSI looks like this:
Do any of those in the thread look like they would work?
I have the SCSI cable that connects to the Falcon, but it's the same connector at the other end of the cable so I don't mind if it's a dongle type adapter or a cable, just keen to get it hooked up.
Not a bad 3d printed adapter either, I'll do a lid when it's all set up properly!
Cheers,
Simon
@smoore100
Oh no you've accidentally grabbed yourself the internal version which uses a 50pin ribbon cable. What you needed is the external DB25 version: https://shop.flamelily.co.uk/v2db25miniuk.html
smoore100
Post by smoore100 »
I was starting to think that actually!
I'll place another order and stick this one on eBay.
Thanks Steve,
Simon
smoore100 wrote: Wed Jun 12, 2024 9:42 am I was starting to think that actually!
Thanks Steve,
Simon
The alternative would have been to buy a second hand external case.
P.S. Oh, just looked on eBay and old external enclosures are extortionately expensive for what is a box, cable and an old, possibly flaky, power supply.
smoore100
Post by smoore100 »
Yep I've placed the order now anyway.
I take it I still need a connector or cable as this appears to be 25 pin compared to the Falcon 50 pins?
