Hi
I'm about to buy one of these:
https://shop.flamelily.co.uk/desktopuk2
I think I'm ok connecting the device via SCSI to my Falcon, pretty sure I have the right lead, but how do I get power to the device?
Many thanks,
Simon
BlueSCSI 2 query
tomster
Re: BlueSCSI 2 query
There's a micro USB plug on the device
If the Falcon provides power over SCSI (I can't remember if it does) then it will provide power. If it doesn't, then you can power it via USB. There is a jumper to select where it gets power from so you can choose.
smoore100
Thanks both
Didn’t spot the USB until I looked closer, just the connector that looked like a floppy power connector.
I shall place the order - stand by for my next set of stupid questions!
Cheers,
Simon
Cheers,
Simon
nolina
Hi,
i am using a BlueSCSI II with my Falcon030 without additional power supply.
There is just the SCSI cable between the BlueSCSI and the Falcon.
smoore100
Brilliuant - that sounds even better, I have placed the order and will see how it goes.nolina wrote: 01 Jun 2024 15:52 Hi,
Many thanks,
Simon
Be really nice if you can get a 3d printed box for it :) mines internal since I've got an internal SCSI port in my falcon. It fits in the case on top of my gotek drive quite nicely.
smoore100
I did find an stl file for an external case which if i can remember where I found it will try it out tonight.
Most of them are just brackets for internal mounting but this one looks ok.
smoore100
calimero
What kind of cable do you have for bluescsi v2?nolina wrote: 01 Jun 2024 15:52 Hi,
using Atari since 1986. ・ http://wet.atari.org ・ http://milan.kovac.cc/atari/software/ ・ Atari Falcon030/CT63/SV ・ Atari STe ・ Atari Mega4/MegaFile30/SM124 ・ Amiga 1200/PPC ・ Amiga 500 ・ C64 ・ ZX Spectrum ・ RPi ・ MagiC! ・ MiNT 1.18 ・ OS X
Users browsing this forum: ClaudeBot, Google [Bot] and 6 guests
