I'm in 2 minds if to just remove those USB and LAN, do I even need them ?
PiStorm Chat
Re: PiStorm Chat
Oh look how cute it is...
After all the times I hated on the Pi, now I own one
Re: PiStorm Chat
I would suggest keeping at least one USB port. You may find it useful when installing software, to connect a USB keyboard and mouse
ATARI STfm, STe, Mega ST, TT
Amstrad CPC464, CPC6128
PiStorm JIT dev - https://github.com/gotaproblem/pistorm-atari-jit
Re: PiStorm Chat
I would assume I would still need the riser if keeping one of the ports because of the height ?dad664npc wrote: Fri Apr 12, 2024 10:28 am I would suggest keeping at least one USB port. You may find it useful when installing software, to connect a USB keyboard and mouse
Re: PiStorm Chat
I thought you were going to use an H5? In which case, I think leaving the furthest USB port stack might clear everythingexxos wrote: Fri Apr 12, 2024 10:29 amI would assume I would still need the riser if keeping one of the ports because of the height ?dad664npc wrote: Fri Apr 12, 2024 10:28 am I would suggest keeping at least one USB port. You may find it useful when installing software, to connect a USB keyboard and mouse
Re: PiStorm Chat
As it's a Pi 4 you'll need a heatsink on the CPU and chipset chips with some sort of fan.
Re: PiStorm Chat
I am...
Re: PiStorm Chat
ah, wish someone had mentioned that before I did the order.stephen_usher wrote: Fri Apr 12, 2024 10:33 am As it's a Pi 4 you'll need a heatsink on the CPU and chipset chips with some sort of fan.
Re: PiStorm Chat
See above - edited reply
Re: PiStorm Chat
I don't use a fan, however, my Pi stands vertically.exxos wrote: Fri Apr 12, 2024 10:35 amah, wish someone had mentioned that before I did the order.stephen_usher wrote: Fri Apr 12, 2024 10:33 am As it's a Pi 4 you'll need a heatsink on the CPU and chipset chips with some sort of fan.
There aren't many of us using PiStorm to be fair, and every setup seems to be different, meaning there is no defacto setup.
Re: PiStorm Chat
I will have a look when I get the other board see how it all fits together.
