C-Lab Combiner reverse-engineering in progress
Hi,
I would like to inform that the schematic of this cartridge switch has been reverse-engineered. The firmware from the protected Altera EP600 chip has also been read and checked. It remains for me to build a working clone based on the restored schematic. When I finish the work - I will post the documentation on www and give info on the forums.
Greetings
tOri
Greetings
tOri
https://reversing.pl/ - SSL enabled site ATARI - Power without price and necessary elementsvarious varieties for Atari and not only - useful or not, but it's worth a look ...
http://atari.myftp.org
Re: C-Lab Combiner reverse-engineering in progress
Hi,
Reverse-engineering of the C-Lab Combiner has been completed. I built a clone that behaves identically to the original
Unfortunately - due to the fact that I didn't have more slots for Atari in 2mm size - I soldered only slot3 position.
In a while a set of documents will appear on my www.
tOri
tOri
@tOriman Congrats! Looks great..
Hi,
The documentation is already on the www. You are invited.
tOri
tOri
Great - well done and thanks again for your contributions!
Wow! Very impressive indeed!
I see you also cloned the Emagic LOG3 on your website.
Do they both work without problems in both Logic and Notator (latest version only)?
STe | MonSTer with dual IDE-CF memory card adapter | NEC Multisync 1990SXi | ST_ESSC | RSVE | Link '97 | Sony HD floppy drive/AJAX controller | Exxos HD floppy module | Battery-backed Ricoh realtime clock module | Discovery cartridge | C-Lab Unitor-2 | C-Lab Export | C-Lab Combiner | C-Lab Steady Eye | C-Lab Human Touch | Unicorn USB
Are you a good person?
Living Waters
Hi,
These are clones so should work seamlessly with both Notator and Logic. I tried LOG3 with Logic and latest Notator it was OK.
tOri
tOri
Excellent! Great worktOriman wrote: Tue Aug 13, 2024 2:03 pm Hi,
tOri
It's impressive all the remake boards you've made! You're literally giving these hardware add-ons a new life.
The Eagle files work fine here, but there was no PCB board layout file as far as I could see (only Eagle schematics) -can you upload these as well (for both the Combiner and LOG3)?
Living Waters
- viking272
Pretty sure the Gerber’s are there on t0ri’s site. I copied his link from the combiner page:Pacman wrote: Mon Aug 19, 2024 11:06 amExcellent! Great worktOriman wrote: Tue Aug 13, 2024 2:03 pm Hi,
tOri![]()
http://atari.myftp.org/atari16bit/combi ... gerber.zip
