Thank you I could only get a reading from the highest setting on my dvm but the 200ohm setting which I also thought should be fine to read with was just reading 1. I am not too sure if this means it is okay or dead.exxos wrote: 27 Mar 2024 22:03 It's a 8.2 ohm fusible resistor. You need to test on something like 200ohm resistance scale on your meter to test it properly.
Mitsumi SR98 issue after recap (no boot)
Groppo91
Re: Mitsumi SR98 issue after recap (no boot)
You would have to consult your meter manual what 1 means. Generally it's "open circuit" on most meters.
But if that resistor is blown then the main switching transistor could well have failed.
