Me too, it's been a long time acquiring everything I need, I guess probably over 20 years now. At least I am in a good position and can afford such things now.
PS4 of Doom...
Re: PS4 of Doom...
Re: PS4 of Doom...
:dualthumbup:
Re: PS4 of Doom...
Okay then. I just got another PS4 from eBay relatively cheap from eBay, just looks like a bad hard drive, which is a quick fix, and there is video out as well, so something to compare the WLOD machine to.
Something weird with the WLOD machine is that it boots to safe mode, and I can reboot as thats the 1st option on the safe mode menu, but I sometimes get data on the HDMI tester, but it then disappears and the 5v indicators start to flash, and hooking up my multimeter via a breakout board, you can see 5v is flicking between just over 5v and about 1.8v when it's flashing. Definitely odd, and I don't get an EDID light either, so I need to find out what should provide that.
The other thing I was able to check with the HDMI breakout board I have is that the differential pairs all connect through from the HDMI encoder to the HDMI socket, so it's something else that is likely the issue, since I already replaced all the line filters for those too.
Re: PS4 of Doom...
Wow, the PS4 arrived quickly!!!
And after replacing the dead hard drive, it's a runner :)
My only concern is that despite being pretty clean, it's kicking out a ton of heat, so I'll pull the lid off, give it a blow through with some air and replace the thermal paste.
Other than that it's good to go.
Re: PS4 of Doom...
:yay2: :cheer: :dualthumbup:
Re: PS4 of Doom...
I'm thinking I now have a good PS4 to refer to for the one with the white light of death :)
Re: PS4 of Doom...
Definitely far easier to fix something if you have a reference system.
Re: PS4 of Doom...
Indeed it is, BUT, after some tinkering, I think it has a bad HDMI port so I think I'll need to replace it as it's a bit iffy.stephen_usher wrote: 21 Dec 2023 15:32 Definitely far easier to fix something if you have a reference system.
Re: PS4 of Doom...
As a bonus it had a game disc in it too :)rubber_jonnie wrote: 21 Dec 2023 16:17Indeed it is, BUT, after some tinkering, I think it has a bad HDMI port so I think I'll need to replace it as it's a bit iffy.stephen_usher wrote: 21 Dec 2023 15:32 Definitely far easier to fix something if you have a reference system.
Re: PS4 of Doom...
And yep, the HDMI port isn't playing ball. It originally worked on the auto setting, but now only on 480p, and it's got worse the more plugging/unplugging that's gone on today.
The original sockets are known to fail with the pins pushing back, so a new HDMI port is on the way.
Users browsing this forum: ClaudeBot, don_apple, gpt [bot], OAI-Search [Bot], petal [bot] and 22 guests
