PS4 of Doom...
PS4 of Doom...
I'd recently acquired a PS4 as a repair project, and only got around to looking at it over the weekend. Here it is:
It's a little grubby, but all in one piece. Unfortunately it has a long pulsing BLOD.
I'd been made aware that it can be configured to include a UART mode in the bios that will dump fault codes to a serial console, so I thought I'd give it a go.
First thing I had to do was find and remove the NOR package, which is essentially the BIOS. I located it next to a large A on the mainboard (A 16 pin TSOP IC), and removed it:
Then I soldered it to my breakout board for reading in my TL866 Pro:
I dumped 3 copies of the NOR before I erased it and then it was a case of using the PS4 wee tools to patch one of the BIN files to enable the UART. I then flashed the patched file back to the NOR and removed from the adapter, and refitted to the board.
I was then able to attach a lead to some pads on the mainboard, ready for connection to my USB serial adaptor as follows:
Although there are 5 connections, and I soldered them all in, only the UART connections are really required for this to work. And we're ready to go:
So once connected, I connected the terminal software to the USB serial adaptor and powered on the PS4 to see this:
Which is good news because I was worried the APU might need reflowing/reballing, which I simply don't have the kit for, but I may just be able to deal with the RAM ICs, which is what this error message suggests it is.
All this info and more can be found at: PS4 UART Instructions.
Re: PS4 of Doom...
New fun!
Re: PS4 of Doom...
Always
I just need to work out which RAM is bad, as although it's block 0/1, quite obvious from this pic:
There are RAM ICs on both sides of the board, and I've yet to discover an image showing both sides...
I suspect the layout may be the same on both sides though.
I can also see if I can determine is any of the ICs are getting particularly hot, which may push me in the right direction.
Re: PS4 of Doom...
Interesting stuff. PS4 is getting quite a bit of homebrew these days. The soft-mod works up-to FW v9.0 (so don't go online and update your FW)
Re: PS4 of Doom...
Before I can go online I need to fix italexh wrote: Mon Jul 24, 2023 5:16 pm Interesting stuff. PS4 is getting quite a bit of homebrew these days. The soft-mod works up-to FW v9.0 (so don't go online and update your FW)
If I can get it going though, I'll certainly look into the soft-mod and I'll be turning off auto updates!!!
Re: PS4 of Doom...
If you get it working you might want to look at getting an ESP32-S2 for self-hosting soft-mod. Although to begin with you can use an Android phone.
Re: PS4 of Doom...
Sounds interestingalexh wrote: Mon Jul 24, 2023 5:41 pm If you get it working you might want to look at getting an ESP32-S2 for self-hosting soft-mod. Although to begin with you can use an Android phone.
Re: PS4 of Doom...
I must now look at my ps4 and see whats wrong with it
I did get two mega ste working with a can of contact cleaner and a tooth brush. And put fpu in both. Funny think both were fitting with the HD floppy parts but just one had the epson 340 drive in it
Tom
Tom
Re: PS4 of Doom...
Good work with the MSTEs, I guess Atari did their usual mess around with the floppies and fitted a mix of parts based on what was in stock.Tomswork wrote: Mon Jul 24, 2023 11:44 pm I must now look at my ps4 and see whats wrong with it
Tom
What's wrong with your PS4?
Re: PS4 of Doom...
It destroyes the os while running and crashs reinstall fixes it for a while. Bad drive bad ram it's a hunt
Tom
Tom
