ACORN A5000 inbound
Re: ACORN A5000 inbound
Post by HigashiJun »
Guess what..
It lives !
I just fit the battery in its holder and connected it to the motherboard, reset the RTC and set the monitor.
:D
Yay! :girldance:
stephen_usher wrote: 30 Nov 2023 08:23 Yay! :girldance:
:cheers:
Woo-hoo!!!
Awesome. Does the IDE work?
rubber_jonnie wrote: 30 Nov 2023 09:28 Woo-hoo!!!
:cheers:
alexh wrote: 30 Nov 2023 09:59 Awesome. Does the IDE work?
Thanks.
The IDE is not tested yet, as 3 or 4 tracks are still to be repaired before I can fit the second buffer.
HigashiJun wrote: 30 Nov 2023 10:15
Thanks.
The IDE is not tested yet, as 3 or 4 tracks are still to repair before I can fit the second buffer.
Don't forget the IDE supports a limited number of drives unless you use something like Wizzo, mine is just a 128MB IDE flash drive, I use SCSI for most stuff.
You'll need !hform IIRC to prep any IDE drives you want to use.
Just one pic for today:
These two tracks were to close to have a bare wire fitted, so I preferred an insulated one.
Anyway, it will be barely visible once the IDE and FDD connectors fitted.
As stated in the previous post, some tracks are still to be repaired and a buffer is still to be soldered.
I don't know why, but I feel motivated.
:lol:
rubber_jonnie wrote: 30 Nov 2023 10:23 Don't forget the IDE supports a limited number of drives unless you use something like Wizzo, mine is just a 128MB IDE flash drive, I use SCSI for most stuff.
Yes, the onboard IDE is somehow limited...
I plan to get myself a ZIDEFS IDE, and I already have the special !hform.
Users browsing this forum: ClaudeBot, Google [Bot] and 18 guests
