Sporniket's log on hardware stuff
sporniket
Re: Sporniket's log on hardware stuff
Post by sporniket »
Before continuing with posting the installation of the mod, it turns out that the wiring to P100 was a wrongly documented, here is the correct wiring :
Now, the continuation :
Intercepting the FDD led signal. On my motherboard, the recommanded via is covered with solder mask, and I did not felt like scraping this location. Instead, I carefully cut the pin 18 of U307 at mid height, lifted the upper part, and soldered the wires there. Of course verifying that there was no bridge.
sporniket
Post by sporniket »
Installing a connector to IKBD Tx (pressing both shift keys and then a key among F1 to F4 select the ROM image to use)
Soldering a wire to the DMA interrupt line
Sourcing the 16MHz clock, I take advantage of the soldered Shifter. Once again, the recommended via is covered by solder mask on my motherboard, so I preferred that setup instead :
The 12V power supply for the LED module :
Preparation of the LED module (that is also sniffing the IKBD Tx for ROM selection) :
sporniket
Post by sporniket »
Time to finish...
Isolating the metallic cans of the various oscillators of the area
Removing the ROMS and setting the jumbers
Plug the board
Connect 16MHz
Connect the 3-wires connectors (FDD led + DMA int, the red wire is not used, isolated and fixed.)
sporniket
Post by sporniket »
Connect the 6-wires connector
Connect the 10-wires connector
Notice the orientation of the flat ribbon cable, the recommanded orientation is so that the flat cable is going up starting from the main board.
Plug the LED module to the ribbon cable, the power supply and to IKBD Tx
Preparing the RTC battery
sporniket
Post by sporniket »
Ready to go
And... after having fixed P100 as mentionned...
I get to the desktop. The IDE is detected but no driver loaded, I have to check my card.
The boot screen of the other ROMs pre-installed. Arne provided a patched 1.06 and 1.62 ROMS to be able to boot from IDE, as soon as my card is correctly setup I presume.
Also, I will have to setup and check the RTC clock.
If I have time this week-end. But anyway, after about one man-day of work, the installation is done.
Darklord
Post by Darklord »
Nice! Congratulations. :)
sporniket
Post by sporniket »
Thanks, I've yet to have a working CF cards, the one I had is not working, my linux computer cannot do anything with it.
Darklord
Post by Darklord »
I've never used CF cards, although I've heard good things about them.
Always went the SD card route with Ultrasatan's and card reader adapters
for use with my Kubuntu Linux laptop and Win10 box. Great, super easy
way to exchange files between machines...
sporniket
Post by sporniket »
CF cards are pluggable into PATA/IDE bus, thus it was an easy conversion for Falcon, if I don't make a mistake. Exchange with modern computer may or may not be easy, depending of how partitionning is done and how the driver works.
sporniket
Post by sporniket »
Waiting payday for buying a new CF cards.
Meanwhile, I finally got something sensible with regard to the modulator part of the ST motherboards. I had too much of discrepencies between schematics and the scanned pcb of the service manual that I was using.
Fortunately, the real motherboard I own had this part unpopulated, so I redid this part with my motherboard on my laps, a glass magnifier with flickering led lights (flimsy push-button), and I improvised something for Q11/R140/R141 that my motheboard had not (but there was footprints for designators that do not exists -anymore-)
Anyway, I got progress on that front too. I also migrated to Kicad 7, that finally allow to attach an image to a layer, so now I can use the scan directly instead of a vectorized version that is full of holes (and takes a lot of places : together with the pair of background image, github started to advise me to try "large file" github...)
Users browsing this forum: ClaudeBot, OAI-Search [Bot] and 13 guests
