STF Remake Benchmarks
Benchmark screenshots for various boosters & machines.
Re: STF Remake Benchmarks
Probably the 99% is due to the slightly slower 32MHz clock.
troed
Post by troed »
exxos wrote: 27 Sep 2018 09:21 Probably the 99% is due to the slightly slower 32MHz clock.
There really should be benchmarks for 8.01/8.02 and 8.05MHz CPUs ;) It's "easy" to detect which one you have from software by measuring CPU speed vs the fix MFP timer clock.
troed wrote: 27 Sep 2018 09:23 There really should be benchmarks for 8.01/8.02 and 8.05MHz CPUs ;) It's "easy" to detect which one you have from software by measuring CPU speed vs the fix MFP timer clock.
Yeah, it's on the "to do list".
I do have some 32.0245 mhz crystals at home. Could wire one and see later once I did my floppy?
Forgottenmyname wrote: 27 Sep 2018 10:15 I do have some 32.0245 mhz crystals at home. Could wire one and see later once I did my floppy?
Go for it :)
Re-ran the benchmark with a 32.084988 MHz crystal I received from Exxos this morning and got a 100% on the STF remake
troed
Post by troed »
Icky wrote: 05 Oct 2018 21:23 Re-ran the benchmark with a 32.084988 MHz crystal I received from Exxos this morning and got a 100% on the STF remake
So, time to run {Closure} ... ;)
:bravo:
Awesome work!
Return to “BENCHMARKS”
