- IMG_3109.png (709.13 KiB) Viewed 9779 times
STF Remake Benchmarks
Re: STF Remake Benchmarks
Probably the 99% is due to the slightly slower 32MHz clock.
There really should be benchmarks for 8.01/8.02 and 8.05MHz CPUs
Yeah, it's on the "to do list".troed wrote: Thu Sep 27, 2018 9:23 am There really should be benchmarks for 8.01/8.02 and 8.05MHz CPUsIt's "easy" to detect which one you have from software by measuring CPU speed vs the fix MFP timer clock.
I do have some 32.0245 mhz crystals at home. Could wire one and see later once I did my floppy?
Go for itForgottenmyname wrote: Thu Sep 27, 2018 10:15 am I do have some 32.0245 mhz crystals at home. Could wire one and see later once I did my floppy?
Re-ran the benchmark with a 32.084988 MHz crystal I received from Exxos this morning and got a 100% on the STF remake
So, time to run {Closure} ...Icky wrote: Fri Oct 05, 2018 9:23 pm Re-ran the benchmark with a 32.084988 MHz crystal I received from Exxos this morning and got a 100% on the STF remake
Awesome work!
