WDIALOG.PRG
General Discussion, STOS.
Cosmic Puppet
Re: WDIALOG.PRG
Post by Cosmic Puppet »
Steve wrote: 10 Mar 2021 11:02 Tone you're getting that 'wdialog needed' message because of the cops accessory. That is also an old version of cops - the latest cops does not even require wdialog.
grab the latest version:
https://bintray.com/freemint/app/cops/1.09-39bd4159
I ended up removing cops as Notator hates it. Then I later switched to NVDI 2.51 which plays nice with Notator after finding some freezes with NVDI 5.
alienkidmj12
Re: WDIALOG.PRG
Post by alienkidmj12 »
i was thinking more of getting jinnee to work under mint with xaaes, i've tried runner.prg and jinnee.app from shell entry, both refuse to work. i'm thinking i either need wdialog or ndialog (latter being the cleaner one, but i think it's for naes only)
mfro
Re: WDIALOG.PRG
Post by mfro »
you don't need wdialog.prg if you are running XaAES as the same already provides wdialog functionality.
arti040
Re: WDIALOG.PRG
Post by arti040 »
COPS 1.09? Anyone? The links seems to be dead. :-(
marss
Re: WDIALOG.PRG
Post by marss »
arti040
Re: WDIALOG.PRG
Post by arti040 »
Thanks! :-)
chronicthehedgehog
Re: WDIALOG.PRG
Post by chronicthehedgehog »
I couldn't get WDIALOG to autoload with Geneva no matter how I configured XBOOT.
While trying to decide whether to stick with NVDI 2.51, I compared 2.51 to 5.03 using GEMBench. It appears that 5.03 is a little slower than 2.51.
Re: WDIALOG.PRG
chronicthehedgehog wrote: 29 Jun 2023 14:08 While trying to decide whether to stick with NVDI 2.51, I compared 2.51 to 5.03 using GEMBench. It appears that 5.03 is a little slower than 2.51.NVDICMP.png
I do believe that 5 is a bit slower than 2.5 IIRC. Though if I remember rightly WARP9 is faster still, but has more compatibility problems.
So it is plausible that version 5 is slower simply because it fixes potentially compatibility issues whereas 2.5 does not. :shrug:
Atari74user
Re: WDIALOG.PRG
Post by Atari74user »
Interestingly NVDI 5.03 is the slowest of all of the NVDIs. Your mileage may depend on what resolution you use, but I did a little test here: https://sites.google.com/view/ataritosser/my-atari/nvdi
AtariTOSser
Medusa Hades 060 512mb, ET4000 / MACH64 | Atari Falcon 14mb, 68882, 8gb CF, Steinberg FDI, FA8, GigaFile & CT60e | Atari Jaguar, GD, Skunkboard & Cat Box | Atari 520STFM 4mb, Exxos Booster, TOS switcher, OverScan, UltraSatan, PARCP-USB, Unicorn-USB, ICD Link 2, ADAP, ADAP II, Lynex, ADAS-ST, SoundPool MO4, Steinberg MIDEX, SMPII, Emagic Log 3, C-Lab Unitor 2, Combiner & ExPort...
chronicthehedgehog
Re: WDIALOG.PRG
exxos wrote: 29 Jun 2023 14:23 So it is plausible that version 5 is slower simply because it fixes potentially compatibility issues whereas 2.5 does not. :shrug:
That would make sense - more bloat less speed :)
Atari74user wrote: 29 Jun 2023 14:23 Interestingly NVDI 5.03 is the slowest of all of the NVDIs. Your mileage may depend on what resolution you use, but I did a little test here: https://sites.google.com/view/ataritosser/my-atari/nvdi
That's an interesting write-up. 3.02 sounds like a good all-rounder. Do you ever use SpeedoGDOS 5.7 with 3.02? I must admit to being a bit confused as to when/where it's needed. It seemed to play nicely with 2.51 and gave me a nice font in ST-guide. Beyond that I'm clueless :D
It's fairly unlikely that I'll ever print anything directly from my ST, however it does feel like an itch that needs to be scratched as I never had a printer BITD.
Return to “SOFTWARE”
Users browsing this forum: Bing [Bot], ClaudeBot and 8 guests
