WDIALOG.PRG
- Cosmic Puppet
WDIALOG.PRG
WDIALOG.PRG appears in Auto folder after installing NVDI. COPS comes with it, but since it adversely affects Notator I decided to delete it.
I'm going to do a fresh install using everything I've learned. I found a download of COPS to see which files it contains.
I notice the download has this WDIALOG.PRG contained in it.
So my question is:
Does NVDI need WDIALOG.PRG to run or is this program for running COPS only?
So my question is:
- thorsten.otto
Re: WDIALOG.PRG
It is only needed by COPS. It is not directly used by NVDI, but you won't have the printer configuration dialogs without it. Also they may be other programs than COPS that require it.
Re: WDIALOG.PRG
NVDI does not require WDIALOG.
WDIALOG is needed by SW originally developed to function under MAGIC (ie. COPS, JINNEE and may be some more) and provides some functionality of MAGIC under non-MAGIC OS. So if You don´t boot those SW then there´s no need to put WDIALOG into the AUTO\; if You wanna start those SW later, it is possible to run WDIALOG just before from the desktop.
Thus spake FN (Frank Naumann) in MiNT\1-15-12\src\doc\install:
"WDIALOG is a very dirty hack, mustn´t be started before MiNT !
Under N.AES use N.DIALOG as a clean replacement!"
So, replacing WDIALOG by NDIALOG might solve Your problem; also, to cancel both WDIALOG and COPS and using xCONTROL or zCONTROL instead of COPS might solve it. Remark: There is no general need to boot either of the three - they all can be started from desktop when needed by replacing the surname .ACC with .APP.
Falcon, TT & some more
- Cosmic Puppet
Re: WDIALOG.PRG
Annoyingly Notator crashes if I try to run MultiTos or Magic, but I don't mind since the new versions of EmuTos support it really well. I tried changing ACC to APP and it works, but what I've discovered is that it drains about 20 Kilobytes from the free RAM in Notator when it's not even started (wasn't expecting that since changing the extension stops it from pre-loading.ari.tao wrote: Mon Nov 04, 2019 7:17 am NVDI does not require WDIALOG.
- Cosmic Puppet
Re: WDIALOG.PRG
If I delete WDIALOG.PRG from the Auto Folder I'll have to put up with this Nag Box.
It works, but oddly drains RAM from Notator, so I'll leave it be.
- frank.lukas
Re: WDIALOG.PRG
The optimum for Notator and Co is a bare TOS system without additions. If need of NVDI use NVDI 2.5 or older ...
- Cosmic Puppet
Re: WDIALOG.PRG
That's what I believed initially, but I have it running on the latest EmuTos with NVDI 5 using the UltraSatan, and it's amazing. (Odd double colon on the pattern name but it doesn't seem to affect the overall function. Just test ran a song. The menus/editors open quicker.frank.lukas wrote: Mon Nov 04, 2019 6:49 pm The optimum for Notator and Co is a bare TOS system without additions. If need of NVDI use NVDI 2.5 or older ...
Just been gathering knowledge and trying lots of stuff to see what my options are (lots of stuff hasn't worked). I like being able to have a desktop shortcuts. Used to autorun Notator and that made it crash a lot. This way I'm just a double click away from start. It also looks quite smart and I can have a shortcut to Music Mouse and the chip editor program.
- alienkidmj12
Re: WDIALOG.PRG
can someone please point me to n.dialog.prg
thanks
thanks
- Cosmic Puppet
Re: WDIALOG.PRG
I don't have it by itself as I now use NVDI 2.51 instead of NVDI 5 because of freezing issues in Notator's score editor.
I do still have the installer which should contain it when installed.
Re: WDIALOG.PRG
Tone you're getting that 'wdialog needed' message because of the cops accessory. That is also an old version of cops - the latest cops does not even require wdialog.
grab the latest version:
https://bintray.com/freemint/app/cops/1.09-39bd4159
