MGI's 65XE
mgi
Re: MGI's 65XE
Post by mgi »
OMG - sorry to hear, are you sure you want to scarify your own?
I will fully understand if you keep yours happy and I own you anyway!
Re: MGI's 65XE
@mgi Its not impossible I have another one around somewhere and if so I'll send it to @rubber_jonnie for his 600.
Re: MGI's 65XE
mgi wrote: Fri Jun 16, 2023 10:28 am OMG - sorry to hear, are you sure you want to scarify your own?
It's fine, I can easily fix the broken pin, but it'll take a little time and I rather get your machine back to you.
I'm sure I'll probably end up with another XL or XE for parts at some point so it's not an issue for me.
Plus it's be a bit of a bind if the pin/solder broke in transit, you'd be in an equally bad position.
So yeah, don't worry about it, it's all good.
Re: MGI's 65XE
PhilC wrote: Fri Jun 16, 2023 10:35 am @mgi Its not impossible I have another one around somewhere and if so I'll send it to @rubber_jonnie for his 600.
Don't worry about sending me another @PhilC I can fix the one you sent and use it for my 600XL, I just need to file back the chip casing a bit to expose enough metal for a strong solder joint.
I'd just rather not send a potentially fragile solder joint through the post.
It's all good.
BTW @mgi may I keep the faulty one? It's of interest to me.
Re: MGI's 65XE
@rubber_jonnie fair enough, I was thinking maybe Dremel the top casing a little so you have more surface area of the pin showing?
Whilst I was looking I did find 3 Pokeys. I can't remember where they came from but looks like I've got some stereo upgrading to do :D
mgi
Re: MGI's 65XE
Post by mgi »
Big thanks gents! I hope I will be able to thank you in person on 8th of October!!!!
mgi
Re: MGI's 65XE
Post by mgi »
rubber_jonnie wrote: Fri Jun 16, 2023 10:42 am BTW @mgi may I keep the faulty one? It's of interest to me.
Of course you can keep it!
Re: MGI's 65XE
PhilC wrote: Fri Jun 16, 2023 10:48 am @rubber_jonnie fair enough, I was thinking maybe Dremel the top casing a little so you have more surface area of the pin showing?
If you have a 7800, you can use one of those Pokeys in a Concerto SD cart. There aren't many games that use it, but it does add flavour to those that do :)
I actually just installed in my 600XL after a little filing on the corner and did this:
So it is pretty strong now.
Then I conformal coated it to prevent oxidation on the exposed part of the leg and zapped it with UV to harden:
All works fine :)
I'll still send you the one from my 600XL to be 100% sure it'll arrive in one piece.
Re: MGI's 65XE
mgi wrote: Fri Jun 16, 2023 10:56 am
Thanks
Re: MGI's 65XE
mgi wrote: Fri Jun 16, 2023 10:55 am Big thanks gents! I hope I will be able to thank you in person on 8th of October!!!!
I'm sure you'll see Phil, but I doubt I'll make it, it's just a bit too far for a day trip :(
Return to “8 BIT CORNER”
