terriblefire wrote: Fri May 26, 2023 2:01 pmThose are much older versions of WhichAmiga than the one you say you have the issue with.
I think the versions from September last year were up to date. The one marked as beta (1.3.25) works fine here. The "official" one (1.3.23) works fine too. I was still using the 1.3.3 version from '99, which caused the system to freeze. Probably because it was too old. My bad, I was using the wrong version. I think the problem with the non-functioning whichamiga is solved.
terriblefire wrote: Fri May 26, 2023 2:01 pmCan I just check you have MMULib installed? Without it you wont get anywhere and you cannot use the B1260 060 library with a TF.
I wasn't sure about MMULib, so I deleted 68060.library from LIBS: and downloaded MMULibs from Aminet and reinstalled just to be sure. I also reinstalled SysInfo from Aminet. And the problem persists. Immediately after starting the SysInfo screen the amiga freezes.
