terriblefire wrote: 26 May 2023 14:01Those are much older versions of WhichAmiga than the one you say you have the issue with.
I think the versions from September last year were up to date. The one marked as beta (1.3.25) works fine here. The "official" one (1.3.23) works fine too. I was still using the 1.3.3 version from '99, which caused the system to freeze. Probably because it was too old. My bad, I was using the wrong version. I think the problem with the non-functioning whichamiga is solved.
terriblefire wrote: 26 May 2023 14:01Can I just check you have MMULib installed? Without it you wont get anywhere and you cannot use the B1260 060 library with a TF.
I wasn't sure about MMULib, so I deleted 68060.library from LIBS: and downloaded MMULibs from Aminet and reinstalled just to be sure. I also reinstalled SysInfo from Aminet. And the problem persists. Immediately after starting the SysInfo screen the amiga freezes.
So i cant get the WhichAmiga you speak of because its been pulled. The version i have works fine here as does SysInfo 4.4.
Can you try a completely clean WB install. Whatever it is sounds software
Just to add to what Stephen said, I tested Sysinfo 4.4 and whichamiga 1.3.3 ,on a TF1260 with OS3.2.2 and 3.2.2 roms and they work no problem, seem like you have some sort of software clash with your system
Well it still could be a hardware issue but lets eliminate software issues first.
IDE Terminator arrived so I fitted that, but my A1200 seems to sit there with internal HD light flashing :( Must have waited at least 30sec with nothing happening.
I've gone back to fitting a IDE to CF with a blank CF card on the internal IDE and it seems to work fine with quick booting.
Higgy wrote: 26 May 2023 23:20
Thats a shame. But i think the blank CF card is a good option. Or you could have a non-bootable "work" partition on that interface.
Wandering round with my laptop flashing TF1260s at the SAUG meet. The feedback is that is a major speed boost in terms of feel in workbench.
terriblefire wrote: 27 May 2023 15:39
i can confirm mine was one of them, and wow what an improvement, so much faster in workbench, and on boot time even on the internal amiga ide
