Iteration 2 tested and working on a 1B board, 3.2.2 ROMs with ehide.device built in. Booting fine from both ehIDE and standard IDE.
Will give 3.2.1 ROMs a go a little later.
Edit: Booting fine on 3.2.1 with built-in ehide.device, again from both standard IDE and ehIDE port on the TF1260.
TF1260 Testing FW
- Admin sponsor
Re: TF1260 Testing FW
Final question.. will it boot with internal IDE disconnected as per @Aardvark82's issue (in 3.2.1)idc wrote: 08 May 2023 18:04 Iteration 2 tested and working on a 1B board, 3.2.2 ROMs with ehide.device built in. Booting fine from both ehIDE and standard IDE.
idc
To clarify, yes, it boots with internal IDE disconnected on 3.2.1 ROMs. My test involved physically moving the same CF-IDE device between the two ports.terriblefire wrote: 08 May 2023 20:07Final question.. will it boot with internal IDE disconnected as per @Aardvark82's issue (in 3.2.1)
- Admin sponsor
Sweet. If @Aardvark82 can confirm we'll call it a stable release.idc wrote: 08 May 2023 22:09To clarify, yes, it boots with internal IDE disconnected on 3.2.1 ROMs. My test involved physically moving the same CF-IDE device between the two ports.terriblefire wrote: 08 May 2023 20:07Final question.. will it boot with internal IDE disconnected as per @Aardvark82's issue (in 3.2.1)
Aardvark82
No, same behavior with iteration 2. When both IDE's are disconnected it's stuck with black screen and doesn't boot from floppy.
supaduper
Same here with iT2, OS 3.2.1 not booting on TF1260 IDE, but does boot on A1200 IDE
Boots with OS 3.2 with a SD card but not wih my CF card , but I suppose that is just because it is a cheapo chinese CF card
- Admin sponsor
And confirm this was a different behaviour on the xmas 2021 alpha firmware?supaduper wrote: 09 May 2023 07:17 Same here with iT2, OS 3.2.1 not booting on TF1260 IDE, but does boot on A1200 IDE
supaduper
Can confirm all working on the Xmas 2021 alpha firmware,terriblefire wrote: 09 May 2023 10:40And confirm this was a different behaviour on the xmas 2021 alpha firmware?supaduper wrote: 09 May 2023 07:17 Same here with iT2, OS 3.2.1 not booting on TF1260 IDE, but does boot on A1200 IDE
but not working on the Iteration 2 firmware, I.E OS3.2.1 works on A1200 IDE but not on the TF1260 IDE
need others to confirm same behaviour
- Admin sponsor
Something broke between iteration 1 and 2?supaduper wrote: 09 May 2023 11:02Can confirm all working on the Xmas 2021 alpha firmware,terriblefire wrote: 09 May 2023 10:40
idc
Will recheck my side.
I tried internal IDE *or* ehIDE, internal IDE *and* ehIDE (booting from one then the other with the opposing device still connected), but I don’t recall trying neither/*nor*… This was both on 3.2.1 and 3.2.2 ROMs on a 1B board. I have a 1D.4 I can try also, if that makes a difference.
