TF1260 Testing FW
idc
Re: TF1260 Testing FW
Post by idc »
Iteration 2 tested and working on a 1B board, 3.2.2 ROMs with ehide.device built in. Booting fine from both ehIDE and standard IDE.
Will give 3.2.1 ROMs a go a little later.
Edit: Booting fine on 3.2.1 with built-in ehide.device, again from both standard IDE and ehIDE port on the TF1260.
idc wrote: 08 May 2023 18:04 Iteration 2 tested and working on a 1B board, 3.2.2 ROMs with ehide.device built in. Booting fine from both ehIDE and standard IDE.
Final question.. will it boot with internal IDE disconnected as per @Aardvark82's issue (in 3.2.1)
idc
Post by idc »
terriblefire wrote: 08 May 2023 20:07Final question.. will it boot with internal IDE disconnected as per @Aardvark82's issue (in 3.2.1)
To clarify, yes, it boots with internal IDE disconnected on 3.2.1 ROMs. My test involved physically moving the same CF-IDE device between the two ports.
idc wrote: 08 May 2023 22:09
Sweet. If @Aardvark82 can confirm we'll call it a stable release.
Aardvark82
Post by Aardvark82 »
No, same behavior with iteration 2. When both IDE's are disconnected it's stuck with black screen and doesn't boot from floppy.
supaduper
Post by supaduper »
Same here with iT2, OS 3.2.1 not booting on TF1260 IDE, but does boot on A1200 IDE
Boots with OS 3.2 with a SD card but not wih my CF card , but I suppose that is just because it is a cheapo chinese CF card
supaduper wrote: 09 May 2023 07:17 Same here with iT2, OS 3.2.1 not booting on TF1260 IDE, but does boot on A1200 IDE
And confirm this was a different behaviour on the xmas 2021 alpha firmware?
supaduper
Post by supaduper »
terriblefire wrote: 09 May 2023 10:40
Can confirm all working on the Xmas 2021 alpha firmware,
but not working on the Iteration 2 firmware, I.E OS3.2.1 works on A1200 IDE but not on the TF1260 IDE
need others to confirm same behaviour
supaduper wrote: 09 May 2023 11:02
Something broke between iteration 1 and 2?
idc
Post by idc »
Will recheck my side.
I tried internal IDE *or* ehIDE, internal IDE *and* ehIDE (booting from one then the other with the opposing device still connected), but I don’t recall trying neither/*nor*… This was both on 3.2.1 and 3.2.2 ROMs on a 1B board. I have a 1D.4 I can try also, if that makes a difference.
Return to “TF360”
Users browsing this forum: Bing [Bot], ClaudeBot and 1 guest
