Wanted: DFB1
wolfman
Wanted: DFB1
Post by wolfman »
Aloha @all,
recently I got myself 2 Falcons:
a) stock Falcon with 14MB
b) Falcon with skunk accelerator and 14MB
I'd like to upgrade the stock Falcon with a DFB1 - but my soldering skills are terrible aka not sufficient to build myself a DFB1.
I'm based in germany...
My first Atari (from 1987):
Atari 260ST, 1 MByte, TOS 1.02, SF314 & SF354 floppy disks, monochrome monitor SM124
I still have this machine ... :D
foft
Re: Wanted: DFB1
Post by foft »
I have one last one with 64MB and the flash chip. I'd saved a PCB for someone, but they changed their mind so thought I may as well put it together :lol: It has a 68030 running at 50MHz.
The FPU is wired correctly since it works at 16MHz. However none of my FPUs run at 25MHz so I can't supply one. I had more luck running some at 20Mhz using a 40MHz crystal (The FPU runs at 50% the speed of the 030 on the DFB1).
Looking for 100CHF + shipping and I can post it from France (is the post on strike?!)
wolfman
Re: Wanted: DFB1
Post by wolfman »
foft wrote: 06 Apr 2023 20:53 I have one last one with 64MB and the flash chip. I'd saved a PCB for someone, but they changed their mind so thought I may as well put it together :lol: It has a 68030 running at 50MHz.
Sounds great!
foft wrote: 06 Apr 2023 20:53 The FPU is wired correctly since it works at 16MHz. However none of my FPUs run at 25MHz so I can't supply one. I had more luck running some at 20Mhz using a 40MHz crystal (The FPU runs at 50% the speed of the 030 on the DFB1).
? You mean the (optional) onboard FPU of the Falcon, or FPU on the DFB1?
foft wrote: 06 Apr 2023 20:53 Looking for 100CHF + shipping and I can post it from France (is the post on strike?!)
Sounds OK for me!
CHF is round about 1:1 to EUR ?
foft
Re: Wanted: DFB1
Post by foft »
wolfman wrote: 07 Apr 2023 10:06
On the DFB1. There is a jumper to run it at 16MHz which I used to test the connectivity. However my remaining FPUs do not work at this speed in the DFB1. I already sold the ones that do with other DFB1s.
Sounds OK for me!
Yes it's 1:1. Paying in EUR or USD is fine (or CHF), I tend to buy things in EUR or USD anyway...
wolfman
Re: Wanted: DFB1
Post by wolfman »
I wrote a PM - hope it got out: message stays in "outbox" ...
derkom
Re: Wanted: DFB1
Post by derkom »
wolfman wrote: 07 Apr 2023 14:01 I wrote a PM - hope it got out: message stays in "outbox" ...
Messages show in "outbox" until the recipient has read them.
wolfman
Re: Wanted: DFB1
Post by wolfman »
wolfman wrote: 06 Apr 2023 20:11 I'd like to upgrade the stock Falcon with a DFB1 - but my soldering skills are terrible aka not sufficient to build myself a DFB1.
Search is over:
@foft sent me his last "surplus" DFB1.
Works as expected - thanks @foft !
Users browsing this forum: ClaudeBot and 162 guests
