It's complete aside from the CPU and fpu. Though they can be supplied also.TotO wrote: 05 May 2023 09:32 Are you ardering the PCB with the CPLD, RAM and FLASH memories already assembled?
DFB1X Falcon booster buyers interests
Re: DFB1X Falcon booster buyers interests
TotO
I mean, the factory solder all the SMD parts? (provided by them or you)exxos wrote: 05 May 2023 09:41It's complete aside from the CPU and fpu. Though they can be supplied also.
All parts soldered at factory.
Rustynutt
Thanks!
Unterseite it is :)
frank.lukas
... there are wirewarp 13mm VG DIN 41612 64pin strips that can be modified/adapted. as with the StromTT and Thunder cards for the Atari TT where the pins look out of the top of the board to put the next board in.
Turbo_Steve
Hi There,
I am also extremely interested in purchasing an assembled DFB1X, as long as the price isn't too crazy. Thank you so much for your hard work on this simple but effective upgrade - the idea of being able to properly use Multi-TOS / Magi!C Falcon without slapping in an 060 based accelerator really appeals.
Rustynutt
Thanks Frank. Some years back found these to use with Mighty Sonic and Afterburner. With the cover off is no problem. Expose can set on AB, and Falcon Speed or NOVA can connect with ribbon cable. Sure, signal is no problem.frank.lukas wrote: 05 May 2023 22:19 ... there are wirewarp 13mm VG DIN 41612 64pin strips that can be modified/adapted. as with the StromTT and Thunder cards for the Atari TT where the pins look out of the top of the board to put the next board in.
This is kind of what I asked you about a PCB so ribbon wasn't necessary.
On the CT picture, use these for testing with SuperVidel. A bitch to remove!
HomeLate
@exxos I'm also interested in a fully build one with cpu/fpu.
Feeling old yet?
Atari 1040STf, 1040STe, Mega ST4 (ST536), Mega STe, TT030, Falcon (DFB1x)...
...and a whole bunch of other retro computers
Added :)
Looks like I may have to start either a second batch buyers list or get more made. I'm a bit reluctant to get more made at this point due to the costs of it all etc
UnderTheRain
I'm interested in a fully built one I have soo many half built projects already lol don't need to add another :)
