CT60 96MHz (without NVDI)
Benchmark screenshots for various boosters & machines.
GB6 hasn't had much testing with the CT60. Caches show some odd results.. So I am not sure if that is correctly working or not.
Though in cases of 030, I talked to DML a lot as with data caches enabled, results were slower, which is actually correct for 030.. So possible 060 datacache could behave the same.. In anycase, if any CT60 programmers out there maybe could verify the cache settings are correct...
Oddly CT60 seems to disabled the blitter :(
DATA CACHE ON - INSTRUCTION CACHE ON
DATA CACHE ON - INSTRUCTION CACHE OFF
DATA CACHE OFF - INSTRUCTION CACHE ON
DATA CACHE OFF - INSTRUCTION CACHE OFF
Return to “BENCHMARKS”
