Phoenix Air - WiFi for the H5 Phoenix
I have been working on a new board for the H5 Phoenix, and it now has a name, Phoenix Air. It is a WiFi board for the Atari, designed with TLS support from the start, so things like HTTPS and secure mail are possible without a PC doing the hard work in the background.
It plugs into one of the 68k IO sockets on the Phoenix. Those sockets are copies of the 68000 CPU socket, so the board sits right on the full 16-bit bus. It does not use the cartridge port at all, so cartridges can still be plugged in and used at the same time.
The hardware is fairly simple. Two ATF1502 CPLDs handle the address decoding and the data side, and talk to an ESP32-S3 module over SPI. The module is the WROOM-1U version with 16MB of flash and 8MB of PSRAM, which gives TLS enough room to work in. It has a u.FL socket rather than an antenna on the module, so an external antenna on a short lead is needed. All the parts are on the top side, and the whole board fits inside the outline of the 68000 DIP64 footprint, about 81 x 25mm, on a 4 layer PCB.
On the software side, the ESP firmware is my own, and so is the network driver on the Atari. The driver will be STiNG and STiK compatible, the aim being that existing network programs work without any changes. The ESP does all the TCP/IP and TLS work, and the Atari just moves the data in and out, which keeps the load off the 68000.
As for speed, on paper the bus side works out at around 1.1 to 1.3MB/s in each direction on an 8MHz machine, and the limit there is the 68000 copy loop rather than the board itself. That is a calculated figure, not a measured one, so I will post real numbers once the boards are running.
Test boards have been ordered from JLC. The CPLD logic, the ESP firmware and the driver are all still to be written, so there is a fair bit of work to do yet. I will post updates as it comes together.
Re: Phoenix Air - WiFi for the H5 Phoenix
Added to my want list :dualthumbup:
Post by JezC »
Me too - and I might even get an H4/H5 board to the point where it is ready to use it! :lol: :roll:
Return to “PHOENIX ZONE”
