Checkmate Retro Styled monitor Kickstarter batch 2
Steve Jones has started a new kickstarter for his retro style 5:4 IPS monitors with 15KHz inputs and lots of other features. It's been running for a while now, a little over 2 days left to go, the kickstarter is fully funded so they are going to be made.
https://www.kickstarter.com/projects/ch ... le-batch-2
I bought a black one to match my Amiga CDTV from the first batch. It is very good (although the first batch turned out to be very expensive but that is being addressed). Here is a video he made using his monitor with an Atari.
If you are wondering who Steve Jones is? Maybe you heard the name? He is an old skool Amiga developer who made the Siamese System back in the day (software and hardware to bring an Amiga and a PC together). He has since made the Checkmate A1500 plus case (A3000 styled case that takes Amiga and PC motherboards). And of course this retro monitor.
I've backed batch 2 as I want a Oyster White colour one to match more closely my Atari ST / Falcon.
It's not the cheapest 15KHz monitor you can buy @£379 + VAT + Shipping. Being totally honest you can buy widescreen monitors from Dell etc. that take 15KHz over VGA for approx. £130. But it is definitely the best looking (in terms of styling). It is the closest to the original monitors in terms of aspect ratio. It has a carrying handle for shows (or going up/down stairs) and you can also buy a padded bag for storage / transport. It has HDMI out for anyone who is doing live streams and wants to feed into a capture card. It is modular and expandable if you wanted to add a Raspberry Pi inside the monitor or a MiSTer there are adapters including internal cables and power.
https://www.checkmate1500plus.com/
Re: Checkmate Retro Styled monitor Kickstarter batch 2
The biggest issues in batch 1 monitors (apart from the price) were
1) "Wigglegate" a mistake in the design of the GBSC based video scaler, some ground or power artifact could affect horizontal video sync. A recall was issued and they were fixed for free. The new design means this won't be an issue for batch 2. More care will be taken to quality check things like this during the development.
2) "Light bleed" a mistake in bezel design / torque settings. When the factory attached the bezel during assembly the torque they used meant that some monitors the bezel put pressure on the panel and you could see the backlight around the bezel. The fix was for users to disassemble their monitor and reduce the torque on the bezel screws. Which was a real PITA and had a risk you'd break something. (You could ship your monitor back for a replacement) This is being addressed with a re-design and better instructions during factory assembly.
3) Closed source software - Some of the monitor used closed source software which meant they were limited in how the user could interact. Resulted in two menu systems and two remotes. This has been addressed with the re-design of the slot-0 board. It's now fully open source and so should feel more like an integrated solution.
