SuperVidel style graphics for the DFB1X2?
I've been having a dig around the SuperVidel recently, mostly out of curiosity, and it got me wondering if something along those lines for the DFB1X2 would be of any interest to people.
It would basically be a cut down version of the SuperVidel. Nothing is decided yet, I'm just trying to gauge interest before I sink any time into it.
The problem is there isn't a lot of info out there on how it is all supposed to work. Nature did publish a register map, and the SuperVidel XBIOS driver turns up as a binary in the CT60 TOS 3.00 release, but I can't find the VHDL anywhere and the drivers are closed source. So a fair bit of it would need working out from scratch.
The other question is the software side. The SuperVidel uses its own NVDI drivers rather than pretending to be an existing graphics card. NVDI also has drivers for ET4000 based cards, so one option would be to make it look like one of those so existing drivers just work. The other option would be to copy the SuperVidel register layout so its drivers could be used instead. The ET4000 route might just be simpler, as it avoids relying on closed drivers that were written for the CT60. I've not looked into either properly yet, so if anyone knows how the ET4000 side of NVDI works, or has any SuperVidel docs I've not found, I'd be interested.
I should also say up front, as it would be hooking into the 030 bus, people can't expect miracles. It's never going to be a CT60 with a SuperVidel. But a faster ET4000 type setup may be relatively simple to build, and that alone could be a decent step up for GEM and higher resolutions.
So, would anyone actually use it? And what would you want from it, higher resolutions on a modern monitor, faster GEM, or something else?
"SuperVidel" style graphics for the DFB1X2?
Re: "SuperVidel" style graphics for the DFB1X2?
I imagine it has to be SuperVidel software compatible or risk having no support?
With the lack of movement on new SuperVidel units there's been a push to make a new SuperVidel compatible gfx card over at Atari-forum. It's still in its infancy but work is ongoing.
https://www.atari-forum.com/viewtopic.php?t=46347
You could consider something totally new? A bridge to a Raspberry Pi Zero? You'd then be able to leverage PiStorm Drivers. And it would be cheap.
I did think about the compatibility side, but the SuperVidel is closed source, so it's a bit of a dead end really. There's no VHDL or driver source out there that I can find, and the whole thing is built around the CT60. It sits on the CT60 expansion connector, and even the firmware updater has to be run in 060 mode. So being SuperVidel compatible on an 030 board would mean copying something nobody can see inside, and then hoping closed drivers behave themselves.
I've also had a better look at the ET4000 side since posting. Looking at the NVDI ET4000 driver source, it relies on a lot of the VGA chip's own hardware tricks for drawing, so faking an ET4000 in an FPGA is a much bigger job than it first looked.
So I'm now thinking more along the lines of a simple Videl type clone. Not so much a graphics card, more a Videl that's had its Weetabix. The main problem with the Falcon at higher resolutions is the screen sits in ST-RAM, which just isn't fast enough. Even 1024x768 in 256 colours needs around 47MB/s just to keep the display refreshed, before the CPU has drawn anything. With the screen in fast RAM on the board, and the 030 writing to it at full speed, the aim would be for existing Falcon software to just see a bigger screen, so no new drivers needed. It would just need a small program to set it all up.
A PCI bridge would be a much bigger job, and more than I want to take on at this point.
Good to see work is ongoing on a new SuperVidel compatible card though. If that comes off, it's probably the better route for CT60 owners anyway.
No. But the design has been licensed twice before. Both never successfully produced units.exxos wrote: Sun Nov 22, 2026 12:07 pm I did think about the compatibility side, but the SuperVidel is closed source, so it's a bit of a dead end really. There's no VHDL or driver source out there that I can find,
You could prototype it using a modified version of Hatari before you touch hardware. This will show you any cans of worms software wise before you spend time and money producing hardwareexxos wrote: Sun Nov 22, 2026 12:07 pm So I'm now thinking more along the lines of a simple Videl type clone. Not so much a graphics card, more a Videl that's had its Weetabix. The main problem with the Falcon at higher resolutions is the screen sits in ST-RAM, which just isn't fast enough. Even 1024x768 in 256 colours needs around 47MB/s just to keep the display refreshed, before the CPU has drawn anything. With the screen in fast RAM on the board, and the 030 writing to it at full speed, the aim would be for existing Falcon software to just see a bigger screen, so no new drivers needed. It would just need a small program to set it all up
Yeah it's a good idea. Now claude can build this stuff, for me developing stuff it can happen way quicker.alexh wrote: Sun Nov 22, 2026 12:43 pm You could prototype it using a modified version of Hatari before you touch hardware. This will show you any cans of worms software wise before you spend time and money producing hardware
