Wolfchild STE
General Discussion, STOS.
TheNameOfTheGame
Wolfchild STE
Post by TheNameOfTheGame »
Here is Wolfchild STE version.
I had been manually reverse engineering Wolfchild in ghidra off and on for a couple of years, but with the advent of AI and the ghidra mcp server, the whole project was accelerated.
With the help of claude opus 5.5, the remainder of the RE project was completed and the entire engine was 100% reconstructed, fully commented and exported as vasm compatible source code.
After that, next was to integrate my hardware phase scroll routine into the engine and replace the stock cpu sprites with tight blitter sprites. Further guided optimizations brought the game from the stock 10fps to ~30fps at 60Hz and 25fps at 50Hz. Music is adjusted at 60Hz. This step was aided immensely by the awesome hatari hrdb-mcp server project. The release of fable 5.2 was also very helpful for the optimization phase.
What is there: Hardware 8-way phase scroll (with scanwrap splits), playfield splits, raster color changes and tightly coupled blitter sprites all remaining within a 512KB game.
What is not there: DMA sound. This is not possible with a 512KB game with this engine, but can be added for higher memory targets. Raster bars color smoothing with the increased STE palette - on the list of improvements to do. Furthur speed improvements possible at 1MB+.
Tested on my STE (and hatari) and MegaSTE (thanks Darklord). Should work on Falcon as well (bug fix for the shadow register usage on the sound chip) but feedback is welcome.
This is a 512KB game, but needs 1MB (because of HAGA).
Why a 512KB target? So I can offer .ST images for those that want the stock experience on real hardware. Let me know if this is something you want. This engine has many cool features - large sprite objects, walking on slopes, breakable objects, moving platforms, scriptable animations, movements and behaviors, etc.
WOLFSTE.ZIP
(941.39 KiB) Not downloaded yet
Return to “SOFTWARE”
