A new C128D project
A new C128D project
As I mentioned in a previous topic, I've acquired a C128D case in reasonable condition, not immaculate but good enough for my project.
A while ago when I was having problems with my original C128D (right before CL2) I got hold of some C128 spares. Amongst these bits and pieces was a non working motherboard.
I got the motherboard fixed, can't remember how now but it's a C128 motherboard, not a C128D. There's not a lot of difference between them. It's all about the power supply. The C128D has a built in one at the front left hand side of the case, with built in IEC socket at the rear and power switch on the left hand side of the case.
The C128 uses an external power brick that looks like the one from an Amiga and even uses the same plug but they are very different. Please don't try plugging an Amiga one in to a C128 or vice versa, it'll find in many tears. The C128 has a power socket and on/off switch on the back tight hand side of the motherboard but with these still fitted, the motherboard won't fit into the C128D case.
Anyway, so I don't have a spare C128D power supply, yes I have some PCBs that work as power supply replacements for anything from a C64 up to the C128, designed to be fitted in the external power bricks.
Now I do have a nice new C128 power supply that I got from Jakob from Retrolemon. So I'm trying with the idea of cutting holes in the C128D case so that I can use that.
I'll probably go for the internal route but that means making up PSU adaptor brackets etc etc... The computer won't look like an original C128D as I've no 1571 floppy drive for it but will likely fit some kind of drive emulator, so a chop here or a hole there won't matter to me.
Some pics of how things are....
Re: A new C128D project
What's with the light strip @PhilC, C128D bling?
Icky wrote: Sun Nov 15, 2026 6:58 pm What's with the light strip @PhilC, C128D bling?
It's got a SidKick Sid replacement, which does stereo Did with FM, Midi out and can also power an LED strip as a stereo equalizer. It had the option, so I had to fit it :lol: I'll incorporate it as a back light somehow on the case.
He wants it to looks like a Ford Escort with running lights at a Southend on sea car event 🤣
rubber_jonnie wrote: Sun Nov 15, 2026 9:09 pm
Yeah but I couldn't remember what those lights are called :P
PhilC wrote: Sun Nov 15, 2026 9:17 pm
I live in Essex so it wasn't hard 🤣
