This news is a little late, it was released over a week ago. Previously SideCartridge Multidevice only supported ROM emulation microfirmware on the TT/Falcon (and Diego categorically said he was never going to develop Multidrive microfirmware beyond TOS 2.06) but the latest release v1.2.0 now supports Gemdrive (hard drive) and FDD (floppy disk) emulation on both TT TOS3.06 and Falcon TOS 4.04 (I'm not sure if they support older TOS versions on these platforms, that is just what it says below)
https://x.com/sidecartridge/status/2104 ... 40658?s=20
If you've never used one, they are excellent. You can download files, disk images and rom images to the SD card in the Sidecartridge using the app on your phone (or from your PC/Mac).
I don't know if it supports networking yet... I'll ask.
SideCartridge Multidevice now supports TT & Falcon
Re: SideCartridge Multidevice now supports TT & Falcon
It's kinda funny but I gave 2 SidecarTridge devices away as prizes at DarkForce! before
I ever bought one and used it for myself.
I've been nothing but impressed so far.
After setting up STing manually before (and ROUTE.TAB!), it was amazing to simply run
an install program and have it do all the work, adjusting ROUTE.TAB for you
BTW, you mentioned TOS v2.06 in a post at the site, if I understood correctly. I'm using
my SidecarTridge with TOS v3.06 here on my Pak 68/3 equipped STacy and it works
great.
It made me really happy since the NetUSBee won't work with the Pak 68/3 board.
Thanks.
great.
Thanks.
Support for TOS v3.06 has been added recently (at least for the Multi-drive uFW). How long ago I don't know (I don't have a TT or a turbocard).Darklord wrote: Wed Oct 07, 2026 4:55 pm you mentioned TOS v2.06 in a post at the site, if I understood correctly. I'm using
great
I had assumed it was at the same time as TOS v4.04 support was added?
You're using the MD/Net uFW with TOS v3.06? There is nothing on Neil's Website to say it supports TT. Maybe reach out to him?
BTW: If anyone (with lots of technical knowledge) wants to see what it's like to have a SideCartridge MultiDevice there is an add-on for Hatari. It's not plug and play but looks interesting.
https://github.com/neilrackett/emumd
Good to know. I use the side cartridge mostly as debugging device (having debug outputs in an interrupt handler = priceless) but I have been uploading binaries by regular means (parcp, Svetlhlana network card).
Yes, I'm using MD/Net with TOS v3.06. Keep in mind, it's not a TT030 but my Pak 68/3 equipped
STacy, which has TOS v3.06.
I'm pretty sure Neil knows I'm using TOS v3.06 because I initially had a problem with upgrading
the firmware (now resolved) and the question of what TOS version I was using came up (IIRC).
Thanks.
(including a few pics, showing it in action)
felicemaggie
Just got myself one of these recently - looking forward to making use of it.
You're gonna love it - enjoy!
PS Make sure you grab one of the 3D cases from their site. Didn't have the bottom shell printed
out in the 1st shot but you can see it in the 2nd. I still need to sand it down a bit and paint it
but all the ports and buttons are accessible and the LED's have holes so they are visible.
