CSYNC in STe and MegaSTe (for RGBtoHDMI)
Pacman
Post by Pacman »
When adding an HDMI video output to an STe or Mega STe (using the Raspberry Pi Zero based RGBtoHDMI) you will need access to CSYNC (Composite Sync) from somewhere inside the computer.
If you scroll down to the bottom of Lukasz Jokiel's blog page on how to connect an RGBtoHDMI to an STe including a modified Amiga 12-bit buffer board there are a couple of sources for CSYNC in an STe:
A) pin 2 of U403 (MC1377) or pin 6 of U211 (74LS04) in RF-modulator equipped STe computers.
B) in non RF-modulator equipped STe computers there's an alternate location in the area of the (non-populated) RF-modulator. I haven't yet located the exact spot in the STe schematic, but there's a photo on that blog page -scroll all teh way down to the bottom) which shows where to tap into it.
So there are STe machines with RF-modulators, STe machines without (typically French machines from what I've heard). There's also the issue of PAL machines in Western Europe and NTSC machines in North America -I don't know if that makes any difference in regards to the CSYNC signal.
Since I'm working on an STe/MegaSTe compatible 12-bit buffer board for use with RGBtoHDMI I'm considering if I should include a small circuit for generating CSYNC to ensure everybody gains access to that signal. I've come across several ways to generate CSYNC if there isn't one available:
There are probably other solutions as well.
With my limited knowledge I'm wondering if obtaining CSYNC externally (using one of the above circuits for instance) will put less of a strain on the Atari circuitry and create a cleaner/better signal, or if it'll just be excessive and not make any difference?
I also want to know if CSYNC is guaranteed available on all STe and MegaSTe machines by tapping into their existing circuitry?
I've examined the MegaSTe schematics and see it's very similar to the STe schematics. Are there MegaSTe machines without RF-modulators as well?
STe | MonSTer with dual IDE-CF memory card adapter | NEC Multisync 1990SXi | ST_ESSC | RSVE | Link '97 | Sony HD floppy drive/AJAX controller | Exxos HD floppy module | Battery-backed Ricoh realtime clock module | Discovery cartridge | C-Lab Unitor-2 | C-Lab Export | C-Lab Combiner | C-Lab Steady Eye | C-Lab Human Touch | Unicorn USB
💧Are you a good person? 💧Living Waters
