Just curious if anyone solved the annoying on /off glitching issues on the CT60?
I remember having it on my original CT60 and also still have the same issue on the CT60. It's been one of those annoyances which never seems to have been fixed by anyone?
CT60 on off fix?
Re: CT60 on off fix?
Can you be more specific?
Do you mean you're still having issues on ct60e?exxos wrote: Thu Oct 01, 2026 7:12 pm I remember having it on my original CT60 and also still have the same issue on the CT60.
I don't have any on/off issues with my ct60e. But I know this can be effected by the power supply used. In previous years when I was testing different PicoPSU's, I noticed the on/off behaviour could change (ie; automatic on when applying power, or not) I ended up settling for one of the 'real' original PicoPSU's from the USA.
The problem where you power on the ct60 and it goes off right away again. I assume it's switch bounce and its seeing multiple pulses for on off. I have to try several times to get it to stay on. Original CT60 and CT60e both have the same issue. Hence asking if anyone diagnosed the issue and come up with a fix for it yet.
Yeah both CT60 and CT60e. Sometimes turning the PSU on itself and its random if it turns on or not without actually touching the power on on the CT60 itself.Steve wrote: Fri Oct 02, 2026 9:24 am Do you mean you're still having issues on ct60e?
Thanks for the info. Have a PSU from them as well powering my falcon dfb1 and its getting very hot indeed. And the computer is acting up after its on for sometimes. I will remove it asap.
Did you mean to post that in this thread? viewtopic.php?f=18&t=8679Oldskool wrote: Fri Oct 02, 2026 10:41 am Thanks for the info. Have a PSU from them as well powering my falcon dfb1 and its getting very hot indeed. And the computer is acting up after its on for sometimes. I will remove it asap.
Oh f… sorry.
Still thanks for the info. Was already doubting that psu.
Should not do this with mobile phone..
