MEGA ST BLITTER INSTALL
The latest tweaks and fixes to keep your machine running in tip-top shape.
If your MEGA hasn't had a blitter fitted from factory, you can easily fit one..
However, there are 2 solder jumpers (circled in red) which need to be removed in order to use the blitter...
Incidentally, if you remove the blitter you have to put the solder jumpers back in place.. though nobody wants to do that :)
Return to “TWEAKS & FIXES”
