Just arrived from USA. (No customs charges thank goodness)
If you don't know the Superstation is a commercial MiSTer clone. The FPGA SoC that has lots of Arcade and Retro computing cores (Including Hybrid cores encorporating PiSTorm).
https://retroremake.co/products/superst ... 4348112919
It will be on the bench over the weekend.
Not a bad price, under £200 including delivery
Latest member of the household
Re: Latest member of the household
I an certainly see the PSOne influence.
Is it just PSOne or will it do other things?
It's a MiSTer clone, an FPGA. Reconfigurable hardware. It can be anything that will fit inside the FPGA.
There is already VHDL/Verilog for :
Acorn BBC/Electron
Acorn Archimedes
Atari 2600/5200/7800
Atari 400/800
Atari ST(e) - You can select 00@8MHz or 020 or 030 accelerator around 30MHz but PiStorm is coming
Atari Jaguar
Atari Lynx
Commodore VIC 20
Commodore C64/128
Commodore Amiga (Including AGA, RTG, AHI and PiStorm+Emu68)
PC Engine / TurboGFX
Nintendo NES
Nintendo SNES
Nintendo Gameboy/Advance
Nintendo 64
NeoGeo AES/MVS (The MiSTer core is the basis of the new NeoGeo AES+ console)
Sega Master System
Sega Megadrive (+32x + MegaCD)
Sega Saturn
Sinclair Spectrum (+128) / QL
Playstation One
Lots and Lots of others.
https://mister-devel.github.io/MkDocs_M ... /computer/
https://mister-devel.github.io/MkDocs_M ... s/console/
https://mister-devel.github.io/MkDocs_M ... es/arcade/
Unlike software emulation MiSTer uses real hardware to recreate the computers/consoles. They are still re-interpretations but they are a lot closer to the original (and in some cases actually use the original designs converted from netlists and schematics)
As well has HDMI out it has analog 15KHz and 31KHz video and analog stereo audio. So it can with the right cable connect to a CRT TV
Pretty capable then, what are your plans for it ?alexh wrote: Fri Sep 25, 2026 11:29 amIt's a MiSTer clone, an FPGA. Reconfigurable hardware. It can be anything that will fit inside the FPGA.
Acorn BBC/Electron
Acorn Archimedes
Atari 400/800
Atari Jaguar
Atari Lynx
Commodore VIC 20
Commodore C64/128
Nintendo NES
Nintendo SNES
Nintendo 64
Sega Master System
Sega Saturn
Playstation One
I can't collect Arcade machines (again). I had about 10-15 but I'm down to just 2. They just take up way too much room and always need maintenance. I think I will mainly use MiSTer to play the odd arcade game on CRT (rather than play Mame on Pi5 as I do today)
Plus there are one or two systems it can do that I can't justify the current eBay prices for (e.g. Sega 32x, Atari Jaguar CD, x68000)
It does look much better over analog RGBS on 28" CRT TV than my Pi5 over HDMI on 65" Plasma even running at 60Hz with VSYNC and CRT shaders
Wow, you could've opened your own arcade, but I get what you mean about maintenance, they do carry a lot of baggage.alexh wrote: Fri Sep 25, 2026 12:57 pmI can't collect Arcade machines (again). I had about 10-15 but I'm down to just 2. They just take up way too much room and always need maintenance. I think I will mainly use MiSTer to play the odd arcade game on CRT (rather than play Mame on Pi5 as I do today)
I can imagine anything looks better over a CRT, I just don't have the space for them.
Isn't this coming from the same people that made the DE-10 Nano almost identical clone, presumably using FPGA pulls?alexh wrote: Fri Sep 25, 2026 10:28 am If you don't know the Superstation is a commercial MiSTer clone.
http://pasti.fxatari.com
Maybe. Retro Remake.used to make "MisterPi" which was a DE-10 nano clone. The founder of R^2 is a guy called Taki Udon who seems at first glance to be an ok guy.
There's another DE-10 nano clone by QMtech
I couldn't say for sure. But they appear to have sold tens of thousands. I wonder if there are enough pulls to satisfy that?
Here is a comparison of Terrasic, QMTech and R^2 boards.
https://whatskenmaking.com/articles/dig ... mister-pi/
