How is your ST/STe color monitor setup?
pixelpusher
Post by pixelpusher »
Hi folks,
I was digging a bit into how the CRT color monitor on the ST/STe as well as on other contemporary machines were setup - looking here at the 320x200 mode (but a similar thing applies to the 640x200 mode on top of the 2:1 pixels of that mode). What I found was
- ATARI in the VDI color modes returned that the pixel dimension wasn't quadratic, but instead a pixel vertically was stretched by about a factor of 1.1 (10%)
- contemporary PC (as long as they weren't in the "new" 320x240 mode) displayed 320x200 with pixels vertically stretched by a factor of 1.2 (20%), effectively making it as large as a 320x240 VGA image (which has quadratic pixels)
- The Apple iigs applied the same 1.2x vertical scaling on its monitor
- On the Amiga it seems to be depending on the NTSC or PAL mode how many lines were displayed (and how the images was stretched vertically)
- Looking at my SC1224 I see a clear difference in height depending on the frequency (50 or 60 Hz) being selected. ATARI''s VDI claim of a 1.1x scaling vertically might work as a middle ground, but it might not be the ground truth.
- You might get away with images scaled vertically by 10% to get reasonable good results on all of these systems (as a 10% difference up or down is tolerable), but a 20% difference (e.g. when using images intended for VGA resolutions or current LCD monitors) is noticable.
So, my questions would be:
- In which mode (50 or 60 Hz) do you use it?
- how is its vertical stretching factor setup or 1:1 pixel matching (e.g. on a modern LCD)?
- In case you have an old ATARI CRT monitor (or you're sure how your ATARI monitor was setup): Was ATARI right with the 1.1x vertical stretching?
Darklord
Re: How is your ST/STe color monitor setup?
Post by Darklord »
I've got that Dell 27" model monitor that works with the VGA2ST adapter
on my Mega STe.
I've got a JVC brand SC1224 monitor on the Mega ST4 that runs my BBS,
and I've got a Goldstar brand SC1224 that I use for testing purposes with
STacy's external output 'n stuff.
I'm in the US so everything is at 60hz, NTSC.
When I run demos's and some other software (games?) from Europe that
shift down to 50hz, PAL mode, I do see a difference in the screen.
pixelpusher
Darklord wrote: Sun Sep 20, 2026 4:47 pm I've got that Dell 27" model monitor that works with the VGA2ST adapter
on my Mega STe.
Hi Darklord,
have you stretched the screen dimension on these monitors vertically (as with 60 Hz images - at least for me - otherwise look a bit compressed compared to 50 Hz), or did software written the US for NTSC already consider this?
Darklord
Post by Darklord »
No, I didn't stretch anything - I just let them run "as is".
It really didn't seem to be a problem...
