Sorted: 5 1/4" 1.2mb HD disk drive
Evening all,
Does anyone have a working as in reading AND writing 5 1/4" 1.2mb HD floppy drive they would like to sell? I've got two that read but won't write unfortunately.
Thanks
Thanks
Re: WTB: 5 1/4" 1.2mb HD disk drive
Hi Phil,PhilC wrote: Wed Sep 16, 2026 8:20 pm Does anyone have a working as in reading AND writing 5 1/4" 1.2mb HD floppy drive they would like to sell? I've got two that read but won't write unfortunately.
I have a 5.25" floppy drive in a big box of junk in my shed somewhere, but I have no idea if a) it works at all or b) it's HD. I don't even have an actual 5.25" floppy with which to test it!
If you're still looking, though, I can try to dig it out and send you some pictures. You can decide if it's worth me sending it over as a punt. No charge. Just postage, perhaps.
@Badwolf Thank you, no rush of course.
It's a Panasonic ju-475-4.
From what I can see from this service manual (https://www.minuszerodegrees.net/manual ... 122000.pdf), it's HD.
It's a bit in need of a clean up & service!
@Badwolf I've seen a lot lot worse. I bet a bit of a cleanup and it'll work fine.
Shall I post it over, then? Will be about £6, first class. Drop me a PM with an address if so.PhilC wrote: Thu Sep 24, 2026 10:19 pm @Badwolf I've seen a lot lot worse. I bet a bit of a cleanup and it'll work fine.
Unfortunately I can't make CL5 this year, else I'd just bring it then.
Yes please, I'll pm you shortlyBadwolf wrote: Fri Sep 25, 2026 12:39 pmShall I post it over, then? Will be about £6, first class. Drop me a PM with an address if so.PhilC wrote: Thu Sep 24, 2026 10:19 pm @Badwolf I've seen a lot lot worse. I bet a bit of a cleanup and it'll work fine.
- mrbombermillzy
@PhilC If you need some floppies for that, just give the nod and I will bring some to CL5.
Yes pleasemrbombermillzy wrote: Fri Sep 25, 2026 7:22 pm @PhilC If you need some floppies for that, just give the nod and I will bring some to CL5.![]()
- mrbombermillzy
Ok. I will bring some along.
