Troubleshooting my Atari Falcon
kgilmore
Post by kgilmore »
Inspired by my purchase of a Mega ST 4, I dug out my old Atari Falcon (4M, TOS 4.02) bought new which hasn’t been used for a number of years. It boots, passes the memory test, but no longer recognises the internal hard drive or the floppy drive. I’ve replaced the floppy drive with a new one so I don’t think that’s the problem. The machine works in that I can change resolution, but not being able to read floppy or hard drives is obviously a big problem.
On balance, what would be the most likely areas to have gone wrong, and would they be amenable for repair to someone with a strong hobbyist background, has an electronics engineering degree (haven’t worked in engineering for over a quarter of a century), but knows his limitations with SMD devices? Given that Falcons are unobtainium or stupidly priced on eBay, I definitely want the machine running again so I can upgrade it and get into 68030 / 56001 programming.
mikro
Re: Troubleshooting my Atari Falcon
Post by mikro »
First start with disconnecting the IDE drive, then reboot again and check the floppy drive.
The Falcon floppy disk drive controller shares the IRQ with the IDE and from experience I know the floppy drive can appear to not work if there is a broken IDE drive connected.
https://www.atari-forum.com/viewtopic.php?f=27&t=18840
Remove the broken IDE drive and there is a high probability the floppy drive will work again.
You can replace IDE drive with a 44-pin DOM that plugs directly into the motherboard. Or an IDE->SD adapter for external access.
kgilmore
Post by kgilmore »
Thank you both for your replies. The original 60 MB IDE drive was going to be junked anyway as it was way too tiny even back when I was using it in the mid-90s.
kgilmore
Post by kgilmore »
I’ve made some progress. After getting a white screen of death after removing the IDE drive and the 286 emulator board I had, I replaced everything and found that it would recognise and read some floppies. It would even display text files, but resolutely refused to run any programs, so I know the floppy port is working, though I suspect the drive itself will need a good clean, or replacement with a Gotek. There’s enough encouraging signs for me to order a 14Mb expansion, 68882, and TOS 4.04. Thanks again for the valuable help.
