Could this be a PSU fault?
Marcopolomint1
Hi all,
I've started playing around (when I say playing around I mean booting, connecting a mouse and monitor) and just received my SidecarT multi device today. It's definitely not behaving (the STE) I suspect the PSU and there's great info here on that to I'll trundle through the PSU info, re-cap info etc with a view to buying your kit Exxxos. But i'll describe the fault anyway as I could well be wrong....
1. Machine booted to GEM OK always, no floppy inserted as I have none, so FDD not yet tested.
2. SidecarT multi I managed to configure fine, got the correct menus on Atari screen.
3. App loaded on sidecart (downloaded the ROM emulator app first)
4. However on attempting to launch the app on the Atari it just wouldn't launch.
5. Power cycle is advised in this instance so I did this. White screen, no boot.
6. Tried again, same.
7. Removed SidecarT from cartridge port, power cycle still white screen regardless how long I left it. FDD LED not cycling or "clicking"
8. Left for 10mins, booted OK.
9. Slight smell of overheating transistor/semi conductor coming from PSU when I wen't up close and sniffed (no smoke, LOL)
10. Had a Moretti beer and didn't panic.
11. came here.
what are your thoughts? Thanks in advance.
I'm happy with all forms of electronic debug/repair. Can get my hands on a scope if needed but have a basic DVM.
11. came here.
Re: Could this be a PSU fault?
So this is a fresh STe you bought recently from somewhere? We don't know how long it has been stored, or it's history?
It's recommended to start with a re-capped, or new PSU overall, that is the bedrock of a system.
Secondly, don't forget these machines often benefit of a 're-seat' (and potentially a contact clean) of any chips in sockets.
Marcopolomint1
Exactly and I know very little about it's history. It was an Ebay purchase. The seller said it was stored for decades! The case is in excellent condition however.
Marcopolomint1
I stripped it all down and discovered that it has 4Mb installed. That's not going to help the power budget either. I need to recap PSU and clean the FDD anyway. I'll think about re-seats of chips after doing that I think...one step at a time.
You can use a Meanwell RD50-A in place of the original PSU, they are quite inexpensive and a very good replacement.
Yeah or Exxos's flagship PSU: https://www.exxosforum.co.uk/atari/store2/#0030
Or his lower cost alternative: https://www.exxosforum.co.uk/atari/store2/#0284
If you want the best, go for Exxos custom one at the top
Marcopolomint1
OK< it's all recapped, load resistor tested but still not stable when the SideCart is plugged in and fine when not using.
I now strongly suspect it's actually the bus resistors as per this thread. it seems fine when playing a game from the FDD; played Lotus Turbo for over an hour no probs.
viewtopic.php?f=17&t=2235#p27504
(9 Pin SIL resistors)
cheers,
Marco.
cheers,
Marco.
@Marcopolomint1 I'm not sure whether you should jump to that conclusion so fast. How about checking the voltage at the cart port first? Make sure it's as close to 5v as possible. Changing the SIL resistors is a risky job depending on how experienced you are with soldering, and I haven't heard of the SILs being a fix for anything cart-port related before.
Have you contracted the guy who you purchased Sidecart from and asked if its a known issue before you start modding other things ?
Marcopolomint1
That's a good point actually, never crossed my mind to ask about known issues on the SideCart. Will check that, along with looking for somewhere to prove the 5v close to the port. Will have a gander at the circuit diagram. Thanks.
Very confident working PCB's etc...I used to go right down as far as sub mil micro wire tuning bond in microwave modules and tiny surface mount in my past life in defence all by hand!
The description on this link virtually spelled out what i'm seeing, quote ""Symptoms can be machine not booting when a cartridge is plugged in, or intermittent crashes or screen corruption in general""
cheers,
Marco.
cheers,
Marco.
