Computer info how to.
Marcopolomint1
How do you get this diagnostics/info screen up? Just booted my newly arrived STE get to GEM desktop ok. I don’t have any s/w yet.
Marcopolomint1
Re: Computer info how to.
Right I better find a way to get it onto a floppy disc. Also I better find a floppy disc, i've literally got nothing!!...and a way to write to floppy discs.....My SidecarTridge doesn't arrive till end of month.
It's not an integrated TOS function. You'll need to wait for your SideCartridge Multidevice.
Or get a cheap USB floppy drive from Amazon to write standard ST disks? (If you go down that route, I would get one that can later be converted to a Drawbridge so you can read/write exotic formats you can't normally do with USB floppy drives.)
The best source of 720KB SDFDs is eBay. Yes they will be 30 years old and yes you will need to check for mould before using them but they are cheap and if you sort by address (Nearest) maybe you can find a local pickup.
https://www.ebay.co.uk/itm/358757534291
I use one of these drives and works fine with 720K formats and 1.44.
https://www.exxosforum.co.uk/atari/store2/#0266
The ones generally found around the internet do not support 720K.
I've got a couple of these as well, seem OK on Win 10 & Win 7 PCs for standard disc formats (720k & 1440k) - I've not tried anything too exotic with them though, just to transfer files between PC and various STs/my Falcon...exxos wrote: Fri Jul 17, 2026 10:24 am I use one of these drives and works fine with 720K formats and 1.44.
Marcopolomint1
So I can just buy that drive, write my Atari s/w or .ST images to the disc on my PC and it will work on the ST drive?
Is there any special software on the PC I need to do that? Or any settings I should be aware of?
I think you'll have a much easier and enjoyable time if you wait for your SidecartMarcopolomint1 wrote: Thu Jul 16, 2026 7:54 pm Right I better find a way to get it onto a floppy disc. Also I better find a floppy disc, i've literally got nothing!!...and a way to write to floppy discs.....My SidecarTridge doesn't arrive till end of month.
Marcopolomint1 wrote: Fri Jul 17, 2026 10:29 am So I can just buy that drive, write my Atari s/w or .ST images to the disc on my PC and it will work on the ST drive?
There are programs which write .ST images back to floppy yes, but I never found them reliable.
For my use cases, I just copy files to my 720K on the USB drive on my PC, and they work fine on ST then.
Extracting files from ST images etc was what I was talking about the other day that having a online extractor would make tasks like this much easier.
https://www.exxosforum.co.uk/forum/view ... 03#p143281
Though I tend to just load them in Steem emulator and copy them to a RAM drive on my PC to extract that way, bit of a faff, hence me talking about having a online extractor.
I've not tried any extended formats yet either. I just tend to jump to 1.44MB disks when I run out of space on a 720K.JezC wrote: Fri Jul 17, 2026 10:28 am I've got a couple of these as well, seem OK on Win 10 & Win 7 PCs for standard disc formats (720k & 1440k) - I've not tried anything too exotic with them though, just to transfer files between PC and various STs/my Falcon...
