Mega ST video output oddity
Atarian Computing
Post by Atarian Computing »
One of my Megas, 2MB rev 5 has a weird problem. When I have a test cart inserted it displays everything just fine in test mode. Hi and low res. However, if I take the cart out it goes out of sync in Hi res. In low res without cart I can see a few bombs but kinda garbled.
I've tried many refurbed psus, I've exchanged the shifter, glue, mmu, and blitter for known good ones. Before I go further, does anyone have an idea where to look for next? And what causes the the output to be perfect with the cart? All tests are fine too.
Edit: Oh, and tried several monitors and adapters that are known to work fine.
Re: Mega ST video output oddity
Sounds like loading on the ROM cart seems to help ? Probably change the SIL's for 2.2K... Had similar problem on my STE few weeks ago, machine would fail to boot when diagnostic cart inserted due to bus loading issues. Sounds like you got almost reverse problem to that.
Atarian Computing
exxos wrote: Wed May 16, 2018 9:39 pm Sounds like loading on the ROM cart seems to help ? Probably change the SIL's for 2.2K... Had similar problem on my STE few weeks ago, machine would fail to boot when diagnostic cart inserted due to bus loading issues. Sounds like you got almost reverse problem to that.
Ah, good point. I'll have to order some and try. Thanks.
Atarian Computing
Ok, so I ordered a good bunch of these: http://uk.farnell.com/bourns/4609x-101- ... k%20bussed
Those are correct, right?
Yep.
Atarian Computing
So I changed all SIPs and no difference I'm afraid. This is weird.
:( So either the loading on the cartridge is snubbing some noise on the bus, or maybe the cartridge has a capacitor on the power rail is solving the problem.. I don't really know what else unless there is a bad connection on the video lead / socket or something..
Atarian Computing
exxos wrote: Fri May 25, 2018 7:24 pm :( So either the loading on the cartridge is snubbing some noise on the bus, or maybe the cartridge has a capacitor on the power rail is solving the problem.. I don't really know what else unless there is a bad connection on the video lead / socket or something..
So what you said gave me an idea. I have Arne's multitest cart with SuperMon. As SuperMon is a GEM app, the machine boots to the desktop. Well, I would just get the same blank screen. Same cart, same conditions, different program on the cart.
It doesn't seem to be a bad connection. Does this give any ideas?
slightly confused what is working and what isn't working.. you mention it was hi-res not working before, now your talking about desktop and blank screens ?
Atarian Computing
Ok, sorry, I'll try to clear it up.
The MST in question only works flawlessly with a test cart *and* the diagnostic test loaded in both hi and low resolutions.
It will only output a blank screen in hi res in any other scenario than the one above
It will output garbled bombs in low resolution in any other scenario than the one above.
You speculated that the cart therefore must have some sort of effect on it. I got the idea of trying the SuperMon program from the same cart as, unlike the test program, it was a GEM program and required it to be started from the desktop. So this is the expected behavior of this program and I've confirmed it with another ST.
However, on the MST, using the same cart where the diagnostic test works in both resolutions, the SuperMon program displays the same blank screen as any other scenario.
So the conclusion should be that the cart itself doesn't seem to affect the operation of the computer but rather a difference between the diagnostic test and normal operation that could help pinpoint the problem.
