Long story short I was monitoring the reset line on a spare 68K IO socket on my scope when I saw this...
Two seconds later I heard my radio wireless clock beep.. Bit of a coincidence I thought..... Then the H5 reset.
I noticed similar earlier that if I strike my soldering iron while monitoring the falling edge of reset, I can clearly see some distortion there. Sometimes I can even get the H5 to reset.
The problem seems to be worse more towards the power supply. Have swapped out my own brand for a SR98 and same issues. The reset IC is under the PSU .
The import to the reset chip has a internal IC pull-up of 68K. Possible its not enough. But if the IC saw a post you would assume a proper reset pulse would trigger.. So there lies my ponder.. I don't have time at the moment to get sidetracked onto another project.....
The H5 has a 10K pull up on the reset output which feeds the LS07 buffers which drives system reset. The output of the LS07 has a 1K pull up on it. So a RF spike could only be most susceptible on the MR pin of the reset chips which has internal 68K pullup. I would think its unlikely a RF spike could counteract a 10K resistor even..
This is the reset IC
Circuit (it will vary a bit depending on H5 revision)
So it would help if other people could actually replicate this experiment and see if it is repeatable on other people's machines.. Even a original Atari ST in comparison would help ..
H5 possible reset issue (WIP)
Re: H5 possible reset issue (WIP)
This happens when I turned the bathroom light on !
You sure you dont have dodgy electrics in your house @exxos
Yeah but im "isolated" via my UPSU on everything in my room.. and my gas soldering iron and radio controlled time clock also causes the issue.
Are you sure it's not the UPS misbehaving then? Half switching to battery with a slightly different phase when it sees a spike on the mains?
How does a gas soldering iron cause mains issues? And only on the reset signal?stephen_usher wrote: Tue Mar 31, 2026 11:12 pm Are you sure it's not the UPS misbehaving then? Half switching to battery with a slightly different phase when it sees a spike on the mains?
Ah, OK. I guess that it will have a piezo igniter.
So, it sounds like it’s an RF issue. Probably a cold joint somewhere acting as a crystal radio receiver.
