STe died. Help? [SOLVED]
Reluctant16bitter
Post by Reluctant16bitter »
My Atari 1040 STe died today while playing Titus the Fox. It froze (both video and audio), and displayed a number of bombs that I didn't count, after which a reset produced just a garbled screen. After turning it off and on again it just showed a brown-red screen that quickly faded to black. A couple of times I succeeded in getting to a floppy desktop since, but now all it seems to do it light up the keyboard LED. The floppy drive is not making any sounds any more and I get nothing but a black image.
After buying the STe, I replaced the power supply with a SidecarTridge. I replaced the 1024Kb with four HYB41256-15 chips of 1024Kb each. I also added a Blitter chip, which was missing, and replaced the faulty keyboard.
I don't have the knowledge to fix this. Is there someone in the Amsterdam area who could have a look at my STe?
Atari 1040STE (4 MB RAM) | Sinclair ZX Spectrum +2A | Sony HB-F1XV MSX2+ (512 KB RAM, 7MHz Z80, WozBlaster OPL4, PowerGraph Light V9990) | Philips VG8235 MSX2 (1 MB RAM, 7MHz Z80) | Mitsubishi ML-FX1 MSX
Re: STe died. Help?
First thing I would normally do is remove any socketed chip, spray contact cleaner, replace chips.
Yours sounds like an older model STe with replaceable blitter, like this? viewtopic.php?t=7419
So I would do this on the CPU, Blitter and Shifter. I would also re-seat the RAM.
Then if this doesn't work... move on to more advanced troubleshooting.
ps - you mention upgrading RAM chips, I assume you mean SIMMs. Or are you mistaking an STf for an STe?
pps - you mention replacing the PSU with a Sidecartridge, I assume you mean one of their PSU replacements, like this or this?
Reluctant16bitter
Re: STe died. Help?
Steve wrote: Sun Feb 22, 2026 7:52 pm First thing I would normally do is remove any socketed chip, spray contact cleaner, replace chips.
Thanks. It's the one in the picture in this thread:
viewtopic.php?t=7938
Steve wrote: Sun Feb 22, 2026 7:52 pm So I would do this on the CPU, Blitter and Shifter. I would also re-seat the RAM.
I'll try that. Thanks!
Yes, I meant SIMMs.
Steve wrote: Sun Feb 22, 2026 7:52 pm pps - you mention replacing the PSU with a Sidecartridge, I assume you mean one of their PSU replacements, like this or this?
The former: this
dml
Re: STe died. Help?
Post by dml »
Do you still have the original power supply?
Do you have a multimeter/voltmeter?
Reluctant16bitter
Re: STe died. Help?
Resocketing the SIMMs was all what's needed. Thanks all!
